LCD display on my 87
Old Apr 8, 2004 | 09:15 PM
Don in Vermont's Avatar
Don in Vermont
Default LCD display on my 87
Hi
I have a question for those who understand the LCD displays on the 87's.
This car is brand new to me and when I drove it home I noticed that 1/2 of the display was not lit. The functions were working but no light. What type of light source is in the displays module ? bulbs ? EL panels ? Any help would be appreciated.
Happy Easter to all on the list.
Don
t
Old Apr 8, 2004 | 09:29 PM
frank j. moran's Avatar
frank j. moran
Default Re: LCD display on my 87 (Don in Vermont)
assuming this is your problem the bulb #882 , about $6-8.00 each, the cluster calls for four. NAPA usually has them....
Old Apr 8, 2004 | 09:38 PM
Z-07 freak's Avatar
Z-07 freak
From: Why are there squished peanut butter cups in my underware?
Default Re: LCD display on my 87 (frank j. moran)
assuming this is your problem the bulb #882, the cluster calls for four.
:iagree:
Old Apr 8, 2004 | 10:17 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Try this link to a great resource for all things digital.
http://www.corvettemagazine.com/2001...igidashpg1.asp
:cheers: -JRC-
Old Apr 8, 2004 | 10:38 PM
okinawa86vette's Avatar
okinawa86vette
Default Re: LCD display on my 87 (JrRifleCoach)
Here's another good link to help with the dash lights.
http://www.corvettemagazine.com/1999...ash/dashp1.asp
Its probably just one bulb the way you described it, but it wouldn't be a bad idea to replace all 4 considering they're all probably the same age.
Chris
Old Apr 9, 2004 | 03:41 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Default Re: LCD display on my 87 (okinawa86vette)
:iagree: Just remember to not touch the bulbs with your bar fingers,, decreases the life... :thumbs:
Old Apr 9, 2004 | 07:27 AM
rick lambert's Avatar
rick lambert
Default Re: LCD display on my 87 (vinnies87)
And you don't need to pull the cluster to replace bulbs-just the bezel-and the little tin caps(4) :thumbs:
Old Apr 9, 2004 | 08:21 AM
SBNova's Avatar
SBNova
Default Re: LCD display on my 87 (rick lambert)
about the "dont have to remove the cluster" thing- he might have to. I recently bought new bulbs for mine. WHile I didnt have to take it apart to get the old ones out- my new bulbs came with the litttle plastic "mount" permanently attached. Requiring disassembly to install the new ones.
Old Apr 9, 2004 | 04:01 PM
Don in Vermont
Default Re: LCD display on my 87 (SBNova)
I cant seem to find any 882 bulbs locally. My local Chev dealer says that the L94 bulb is what is now called out in their parts list. Do you know if the L94 is a direct replacement ?
By the way, thank you very much for the tips.
Happy Easter
Don
Old Apr 10, 2004 | 01:56 AM
JrRifleCoach
I found some at Wally-World. 'bout 6 bucks a piece. Everywheres else they run almost ten. Check the net, always a deal out there in cyberspace. :thumbs:
[Modified by JrRifleCoach, 11:11 PM 4/9/2004]
To LCD display on my 87
