Opti spark
Old Apr 9, 2004 | 07:43 PM
greenvette95's Avatar
greenvette95
St. Jude Donor '03
Default Opti spark
I'am going to replace my opti spark in a few weeks, If haveing the tools how much time should it take? I'am not a super mech but I know my way around engines. Thanks. :flag
Old Apr 9, 2004 | 08:00 PM
R23HTC's Avatar
R23HTC
Default Re: Opti spark (greenvette95)
Moving the damper out of the way was the hardest part on mine. 1/2 day if your good and have some help. All day if you take your time. 2 days with several beer breaks! :jester :cheers:
I REALLY hate the GM opti though. I've had WAY to many problems with them. I finally broke down and went with the DynaSpark. So far so good.
Old Apr 9, 2004 | 08:08 PM
bogus's Avatar
bogus
Default Re: Opti spark (R94 LT 1)
that balancer is a bitch... the best way to do it... jack the car up and get under... uh, first, remove the 3 bolts that hold the balancer to the hub... :D
then get under with a chunk of 2x4 and a hammer. using the 2x4, place it at about 4 o'clock and wack... move over to 8 o'clock and wack... move back to 4... back to 8... and it will fall off, eventually.
Old Apr 9, 2004 | 08:21 PM
greenvette95
St. Jude Donor '03
Thanks Guys, I ordered an opti from last detail. :flag
Old Apr 9, 2004 | 08:22 PM
greenvette95
St. Jude Donor '03
Thanks Guys, I will order an opti from last detail. :flag
Old Apr 10, 2004 | 08:44 AM
pci_raid's Avatar
pci_raid
Default Re: Opti spark (bogus)
:iagree: The most difficult part of opti replacement is removal of the vibration damper.
I found it helped alot to remove the coil/ignition module assembly as it gets in the way of removal and re-installation of the water pump. Other than the damper and mess from the lower water pump bolt, its actually pretty easy.
Good luck
Old Apr 10, 2004 | 09:07 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Make sure and only hit on the inside part of the damper. That is, inside of the rubber. The optis in my TLD catalog are pretty high. Sam Taylor Buick-Cad has them for $299 unvented and $215 vented. Brand new GM, of course.
Old Apr 10, 2004 | 10:56 AM
96BLKTN's Avatar
96BLKTN
Default Re: Opti spark (Corvette Kid NC)
I just got mine from Sam Taylor it shipped to the door from call in 2 days!!!!! WOW GREAT ask for Jason Cromer. I have already installed the underdrive crank pully it is a pain use LOTS of WD-40. I also had to remove the engine mounting bolts and jack up the engine about 3-4". I have a new coil and wires but after testing them with a meter the coil wire has 12 m ohms this ain't right so now I'll have to make a new one. I also got a new waterpump $140 and cheap ins.....
Old Apr 10, 2004 | 11:49 AM
John Row's Avatar
John Row
On disassembly, be sure to mark the plug wires very well.
On reassembly, be sure to fully seat the plug wires back on the opti. The boots go down to almost touch the body of the opti. I gave them a good dose of dilectric grease as well.
Before you replace the water pump start the car. You can run it for 10-15 seconds without any damage.
I would also recommend that you disassemble the new opti and put a nice even bead of hi-temp RTV around all the seal surfaces.
Take your time and get the water pump mating surfaces perfectly clean. This is probably the hardest part of the job.
Some will probably cringe at this suggestion, but to loosen the dampner, loosen the three bolts about 1/2 turn, soak them with penetrating oil and start the car. Shut down immediately. Voila, loose dampner.
Old Apr 11, 2004 | 02:06 PM
JasonL's Avatar
JasonL
Default Re: Opti spark (John Row)
:iagree: Remember the wires need two clicks on the opti end to be fully seated.
Just did an F-body opti yesterday. I used a crowbar on the balancer just like I did on my car. Just be gentle and nudge it loose, working it side to side, don't let it get too crooked. Shouldn't take more than a few minutes. Lots of penetrating oil.
Water pump gaskets: what a pain. A wire wheel helps bigtime.
Old Apr 11, 2004 | 02:07 PM
JasonL's Avatar
JasonL
You had that blue corrosion problem right? It went away with the Dynaspark?
Old Apr 11, 2004 | 02:10 PM
R23HTC's Avatar
R23HTC
Default Re: Opti spark (JasonL)
So far so good! :thumbs:
Old Apr 11, 2004 | 02:58 PM
ninetyfivevette's Avatar
ninetyfivevette
Use a 3 jaw gear puller to take the dampener off. I spent 2 weeks on and off trying to get it off taping on it, spraying it with various things. Gear puller took exactally 2 minutes to get it off. Make sure you get a smaller one so it will fit between the brace and the balancer. I think I used a 3".
Old Apr 11, 2004 | 03:21 PM
Corvette Kid
I wouldn't be afraid to do that at all, in fact I think it's a good idea. What I WOULDN'T do is use the 3 jawed puller, not if you're pulling on the outside part of the damper. You could begin to separate it from the rubber and ruin it. A damper should never be stressed in that way.
[Modified by Corvette Kid NC, 3:24 PM 4/11/2004]
Old Apr 12, 2004 | 01:32 PM
ninetyfivevette
Perhaps I should clarify, I used it to pull from the center, metal part. Pulling from the rubber isolated outside ring is obviously a terrible idea and anyone knowing what they are doing would know what I was implying.
Old Apr 12, 2004 | 01:35 PM
96BLKTN's Avatar
96BLKTN
Got everything off and the plug wires aren't long enough. I order some Taylors should be here in a couple days. The waterpump gaskets were a PITA. And routing of the wires are also. So she should be back together later this week... :rant:
Old Apr 13, 2004 | 11:00 AM
John Row's Avatar
John Row
Default Re: Opti spark (96BLKTN)
One more thing (probably a lot more...).
Use thread sealant on the water pump bolts. They go thorugh the block into the water jacket. It prevents weeping and makes them easier to remove next time.
I coat both sides of the water pump gaskets with a thin layer of hi-temp RTV and let them dry. Just in case you have to remove the pump again, it makes gasket removal much easier.
- JR
To Opti spark
Old Apr 13, 2004 | 01:50 PM
96BLKTN's Avatar
96BLKTN
Thanks for the tip. I noticed that they had sealant on them when I removed. I'm waiting on new wires now to put all back together.
Old Apr 13, 2004 | 02:00 PM
derv3tt3's Avatar
derv3tt3
Do you have to pull the radiator for a opti change? :rolleyes:
Old Apr 13, 2004 | 02:05 PM
96BLKTN's Avatar
96BLKTN
Default Re: Opti spark (derv3tt3)
No, waterpump, balancer, belt, belt tensioner, maf, not that bad but like everything else on these cars it is a PITA.... :steering:
