WILL NOT START AFTER STORAGE !! act III !!
Old Apr 10, 2004 | 10:56 AM
devil427's Avatar
devil427
Default WILL NOT START AFTER STORAGE !! act III !!
this is a 88 convertible model . any idea welcome :rolleyes:
Old Apr 10, 2004 | 11:19 AM
jimbomill's Avatar
jimbomill
Default Re: WILL NOT START AFTER STORAGE !! act III !! (devil427)
I'm in the same boat with my '92!
I just had the Corsa Exhaust system put on and then put it away in the garage for the last 5 months - I even disconnected the battery's negative connection and now, nothing, not even the radio.
Old Apr 10, 2004 | 11:20 AM
cdnguyred88's Avatar
cdnguyred88
What have you checked so far...battery, battery cables, fuses, fuel pump.....etc???? :confused:
Old Apr 10, 2004 | 11:44 AM
devil427's Avatar
devil427
Default Re: WILL NOT START AFTER STORAGE !! act III !! (cdnguyred88)
HI !
I've check almost everything: fuel pump: 42psi , good sprk plugs firing , fuses ok , new gas , but sparks plugs are dry ..., how many voltage must receive an injector ? may be they don't open ... :confused:
Old Apr 10, 2004 | 08:29 PM
Pete K's Avatar
Pete K
Buy or borrow a noid light. This light will flash and let you know if injectors are firing.
To WILL NOT START AFTER STORAGE !! act III !!
