weather strip behind head
Old Apr 10, 2004 | 12:06 PM
mjfox's Avatar
mjfox
Default weather strip behind head
any one replace the weather strip that is behind your head for the roof and side windows.
thanks mike
Old Apr 10, 2004 | 12:35 PM
BAM92's Avatar
BAM92
Default Re: weather strip behind head (mjfox)
That is probably the easiest of them all. Cleaning the old one out took most of the work.
Old Apr 10, 2004 | 12:42 PM
Bans25's Avatar
Bans25
Default Re: weather strip behind head (BAM92)
What is the process to replace it?
Old Apr 10, 2004 | 02:27 PM
BIG JIM 54's Avatar
BIG JIM 54
Default Re: weather strip behind head (Bans25)
Process?
Well, you take the old one off and glue the new one on. It's not rocket surgery!
It's called the Halo weatherstrip.
Pull the plastic hold-downs at the ends with a pair of dykes but be careful. You'll using them again. Use a narrow putty knife and a heat gun to lift a corner. Then with this putty knife, big screwdriver and the heat gun with a concentrator on it, heat the glue where it's stuck to the body a little at a time and pull. If your good and lucky the glue will all come up with the old rubber and leave a nice clean area to glue onto. Get some 3M black weatherstrip glue at the parts store. Hold it down with duct tape until the glue sets. Put the plastic hold-down pins back in. You're done.
BIG JIM
To weather strip behind head
