knock question
Old Apr 10, 2004 | 10:51 PM
Ramanstud's Avatar
Ramanstud
Default knock question
If I'm getting 5-12 degrees of knock retard under WOT, but everything else is perfect under all other conditions, would this indicate a necessity to switch to cooler plugs? I'm running cut-back AC delco 41-629's right now- is this around what most people use?
The car is a touch lean at times, so I'm going to bump up the fuel pressure and see if it changes first.
:lurk:
Old Apr 10, 2004 | 11:00 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: knock question (Ramanstud)
If it's running lean with a stock t-stat that would account for some ping.
You might also back off the timing a tic or two.
