Air conditioning fan current draw??
Old Apr 11, 2004 | 04:38 AM
Vetteboy77au's Avatar
Vetteboy77au
Default Air conditioning fan current draw??
Does anyone here know what a standard (newish) air conditioning fan on a 1986 vette draws?? I measured mine at 25A which seems high, however I have never measured these types of fans before...
All help is appreciated.
Chris
Old Apr 11, 2004 | 11:36 AM
lead foot 85 vet's Avatar
lead foot 85 vet
Default Re: Air conditioning fan current draw?? (Vetteboy77au)
I've heard the fans use about 1 amp per inch of blade length...so if your fan was running with the a/c on thats about right.....wait are you asking about the a/c pump or fan?...........if just the fan that is kinda high.
Old Apr 11, 2004 | 02:03 PM
jfb's Avatar
jfb
If you are talking about the fan at the rear of the engine radiator, I measure 14 amps on my 87 vette which uses the same motor as an 86. 25 amps is excessive.
Old Apr 11, 2004 | 08:00 PM
Vetteboy77au
Default Re: Air conditioning fan current draw?? (jfb)
Sorry for the confusion.
No, I am talking about the air conditioning blower motor, which is mounted on the firewall on the passenger side.
[Modified by Vetteboy77au, 1:01 AM 4/12/2004]
Old Apr 12, 2004 | 11:18 AM
SunCr's Avatar
SunCr
GM's will draw about that amount on high, more if they're worn - check wiring as it's prone to melt at the connector since it's only a crimp. If the insulation is discolored, disassemble the weatherpak and add a little solder to each connector.
To Air conditioning fan current draw??
