What needs to be done when going from A4 to M6 using TunerCat?
Old Apr 11, 2004 | 03:15 PM
ninetyfivevette's Avatar
ninetyfivevette
Default What needs to be done when going from A4 to M6 using TunerCat?
I'm doing a ZF6 conversion this month and I am wondering what needs to be done programming wise on the PCM. Is it as simple as checking the "Manual" box on the Speed Calibration page of Tuner Cat?
Or would I just set all the shifting tables to 255 or 0?
Thanks!
Old Apr 12, 2004 | 10:05 PM
scorp508's Avatar
scorp508
Default Re: What needs to be done when going from A4 to M6 using TunerCat? (ninetyfivevette)
Don't forget to change your idle speed.
Old Apr 13, 2004 | 01:37 AM
ninetyfivevette
Default Re: What needs to be done when going from A4 to M6 using TunerCat? (scorp508)
What is a good idle speed? Stock, fully warmed, normal conditions with an A4 is 550 or 650, with the hot cam, PCMFORLESS has the idle at 850-950 under most circumstances. Would something like 750 be better?
Old Apr 13, 2004 | 10:36 AM
-=Jeff=-'s Avatar
-=Jeff=-
you will need to set all the TCC Tables and Constants to 0
as well as the check marked box for Auto/man.
Thanks should be all
Old Apr 13, 2004 | 12:35 PM
ninetyfivevette
Default Re: What needs to be done when going from A4 to M6 using TunerCat? (-=Jeff=-)
Great, thanks. Hopefully the salvage yard will get back with me soon so I can order up a trans!
To What needs to be done when going from A4 to M6 using TunerCat?
