I have an '86 Vette with a digital speedo. Currently the VSS is driving
the dash through the stock '86 ECM. I would like to be able to provide
the VSS to the dash and the '95 ECM at the same time. Does anyone know
if this is possible or know of links to pages where other people have
done something similar?
Cheers!
Karl Litterer
'86 Vette W/'96 LT4 and '95 ECM
I think you can just split the signal from the VSS and run it to both. Although ther might be an output from the ECM for the VSS and then you could run from the VSS to the ECM then to the Dash
