Need a crate engine
Old Apr 16, 2004 | 03:00 AM
K87ZZ4's Avatar
K87ZZ4
Default Re: Need a crate engine (trupp)
I've been running my ZZ4 for nearly 5 years, now. The biggest hassle was making room for the bigger damper on the ZZ4, or you can use the one off your L98 (I didn't feel comfortable doing that, tho).
I sold the new parts that I couldn't use with the TPI to get a few bucks back in my pocket. It's been a fast-running engine with more goose than the L98, so I feel like I've nearly got the ponies of a C5 :)
Old Apr 16, 2004 | 08:25 AM
da747's Avatar
da747
Default Re: Need a crate engine (amswak)
one word.... ZZ572 baby :thumbs:
Old Apr 16, 2004 | 08:39 AM
Mrcorvette91's Avatar
Mrcorvette91
Default Re: Need a crate engine (da747)
TA, Here as a pic of my Boss Hoss:
[Modified by Mrcorvette91, 8:40 AM 4/16/2004]
Old Apr 16, 2004 | 09:39 AM
MrSpeedyBob's Avatar
MrSpeedyBob
Default Re: Need a crate engine (Mrcorvette91)
:D :D :thumbs: :thumbs: That's the bomb dude. :thumbs: :thumbs: :D :D
Old Apr 16, 2004 | 03:34 PM
Mrcorvette91
Default Re: Need a crate engine (MrSpeedyBob)
Thanks, MrSpeedyBob...Talk about a torque rush opening the 4-barrel... :thumbs:
Old Apr 16, 2004 | 06:24 PM
Bluewasp's Avatar
Bluewasp
NoVa Events Coordinator
St. Jude Donor '14
That bike is insane!! Wow!! :eek: :eek: :eek: :eek: :thumbs: :thumbs:
Old Apr 17, 2004 | 03:25 AM
TA's Avatar
TA
Outstanding :cheers: :cheers: :cheers: :cool:
Old Apr 17, 2004 | 05:17 AM
TIMSPEED's Avatar
TIMSPEED
Default Re: Need a crate engine (TA)
I would personally try to find a local machine shop to clean up your block, punch it .030 over, and then you can get a good deal for a rotating assembly (crank, pistons, and rods) on the internet somewhere, then get a nice Cam (Maybe LPE219), and be on your way. I gurantee, you can do it that way, get better crank/pistons/rods for cheaper or equivalent to the Crate Motor Price.
Old Apr 20, 2004 | 11:44 PM
JCAIRE2's Avatar
JCAIRE2
Default Re: Need a crate engine (TIMSPEED)
if its a decent machine shop, you won't get out of there for less than 4k with machining and assembly. if it's a shady shop, then i could see it being cheaper but not likely. the reason the crates are so cheap is volume. machine shops charge by the quality of the work.
Old Apr 21, 2004 | 06:57 AM
96LT1's Avatar
96LT1
Default Re: Need a crate engine (JCAIRE2)
:iagree:
Any machine shop worth their work is going to be more expensive than a crate. (Family, friends excluded). Ones that say they can do it cheaper are lying to fish you in or they are cutting corners.
A crate motor is the only way to go for a quality low buck solution.
Old Apr 21, 2004 | 07:42 AM
amswak's Avatar
amswak
Default Re: Need a crate engine (96LT1)
After over 6 months of trying to figure out what to do about my slowly dying engine I came to this same conclusion. Rebuilding it is really best if you are just doing it as a hobby, not when you are trying to get your daily driver up and running again. Also if you decide to save some costs by doing some of the work yourself and you screw up that work has no warranty, whereas a crate motor does.
