Preemptive Strike?
Old Apr 12, 2004 | 11:28 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Default Preemptive Strike?
I have an 87 vert with only 41,000 miles, auto trans, pretty well all original equipment except for the alternator, brake pads, tires, radiator hoses, mufflers. Is there any advantage to replacing some of the parts before they go? The car is now over 17 years old. I am in the process of replacing the plugs, wires, coil, PVC valve, radiator cap, thermostat, O2 sensor, EGR valve, all hoses, fluids, and tranny filter. I am doing all this even though it runs perfectly. Should I go ahead and replace the sensors while I am at it? I'm thinking it might be a good idea to replace the TPS and IAC. Or should I just wait till they break? If I am replacing things, then what else should I replace? Am I just another crazed fanatic? :crazy: :crazy:
Old Apr 12, 2004 | 11:39 PM
vetteseniorcit's Avatar
vetteseniorcit
Default Re: Preemptive Strike? (corvetteronw)
I dunno, you sound perfectly sane (for a Corvette owner) to me. :lol:
Old Apr 12, 2004 | 11:49 PM
bogus's Avatar
bogus
oh, God yes. time will kill these parts.
also consider any seal and gasket...
Old Apr 13, 2004 | 04:51 AM
dzierke's Avatar
dzierke
Default Re: Preemptive Strike? (bogus)
:bs
I fully agree with changing seals, gaskets, fluids and hoses but I wouldn't mess with sensors if you aren't having issues with them to begin with. I'm not thrilled with the quality of replacment sensors from GM. Aftermarket sensors very in quality by brand.
Old Apr 13, 2004 | 04:57 PM
Unriced's Avatar
Unriced
Default Re: Preemptive Strike? (dzierke)
:iagree:
If it aint broke, don't fix it...
There is no guarantee that new parts will act like new parts should..
Sometimes you can introduce new problems by replacing stuff that isn't
broken. Hate to say it, you're kinda asking for trouble.... I have worked
in electronics repair for years and know this first hand... Leave it
Old Apr 13, 2004 | 07:58 PM
Ramanstud's Avatar
Ramanstud
Default Re: Preemptive Strike? (Unriced)
I agree- if you drive the car, you'll "develope" problems all on your own and thus have a reason to pull things apart. Often I'll tear into one project and then discover another, etc... so save your money and wait for something to crop up 'naturally.'
Old Apr 13, 2004 | 08:03 PM
joeveto's Avatar
joeveto
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Contributor
I recently confronted this as well. But I was in a different spot. My wife's C4 had over 106K on it, and I didn't know the service history. Once the fuel pump died and left us stranded, I decided to do, as you put it so well, a peremptive strike. I like that.
At any rate, I replaced the fuel pump, all the sensors, had the injectors blueprinted by Rich at Cruizinperformance, new valve springs, cap and rotor, ignition module, plugs, wires, and now, the cam and lifters. Basically, once it's back together, I want to know it will be dead reliable, and the tow truck won't be making another visit for quite some time.
So I don't think you're crazy. But I do agree with others, that at your mileage, your sensors are probably okay. I'd be more concerned about hoses and such. All the rubber parts.
Old Apr 13, 2004 | 09:10 PM
bogus's Avatar
bogus
Default Re: Preemptive Strike? (joeveto)
technically, it's called "Preventitive Maintenance". and I am a firm believer in it.
the older C4's have issues with wiring harnesses and heat damage... I cannot believe that the original sensors are better than a new part. And the last thing I want is an old part failing, at the most inopportune moment, when I have to spend $$ at a dealer for the replacement.
To Preemptive Strike?
