change oil lite
Turn key on but do not start engine.
Within 5 seconds press the ENG/MET button.
Within 5 more seconds press the ENG/MET button, again.
Now, I get a little fuzzy, press and hold the Gauges button. The Change Oil light should either be flashing or steady (don't remember which)... Hold the Gauges button till the light changes state (i.e. flash to steady or steady to flash). It takes a good 15-20 seconds.
You're done. Turn the key off. Start the car. The light should be off for another ~3500 miles.
[Modified by John Row, 8:17 AM 4/13/2004]
https://www.corvetteforum.com/techti...=255&TopicID=2
