More on weird indicator.
Old Apr 13, 2004 | 03:49 PM
wbco's Avatar
wbco
Cruising
Default More on weird indicator.
Yes, when I turn the lights on, the indicator is off. When I go to high beams the indicator comes on and stays on even though the head lights switches back and forth normally. When I switch the light off and then back on the incator is off, until I go to high beam, and ect, ect. Is there anything conected with a headlight door module that would light the high beam indicator. According to my manual, the only thing in that circuit is the head light switch, the dimmer, and the indicator. I,m stumped. :withstupid:
Old Apr 13, 2004 | 04:32 PM
TA's Avatar
TA
Default Re: More on weird indicator. (wbco)
Sorry, I can't help you on your problem, but might I suggest you put all additional info in the same thread instead of starting a new one each time. :yesnod:
Old Apr 13, 2004 | 04:37 PM
QuikZilver's Avatar
QuikZilver
Possible problem with your high beam switch...
:confused:
Old Apr 13, 2004 | 05:18 PM
wbco's Avatar
wbco
Cruising
Ok, I new to forums. :rolleyes:
To More on weird indicator.
