Failed Emission's Test
Old Apr 13, 2004 | 04:09 PM
imaflip1356's Avatar
imaflip1356
4th Gear
Default Failed Emission's Test
My 86 did not pass emission's test due to high NOx. Does anybody have suggestions where I can start with this and what affects this condition?
Old Apr 13, 2004 | 07:05 PM
Skippy Stone's Avatar
Skippy Stone
Default Re: Failed Emission's Test (imaflip1356)
Wow, this is an open question. You may have mechanical problems not related to the ECM. If you have done a complete tune-up on the car, then post this in Tech-performance to see what other people think you should check.
Old Apr 14, 2004 | 01:51 PM
imaflip1356
4th Gear
Default Re: Failed Emission's Test (Skippy Stone)
Thanks for the reply Skippy Stone.
The car sit's in the garage all winter and gremlins must come out and do their job since it was running great before storing it for winter. I will do a tuneup and see how it goes.
Old Apr 15, 2004 | 01:22 PM
Skippy Stone
Default Re: Failed Emission's Test (DOCTOR J)
imaflip1356
See what I mean?
Old Apr 15, 2004 | 02:19 PM
imaflip1356
4th Gear
I've changed the plugs, they all look at least close to normal except for one that was badly fouled up, no wonder it also ran rough. I hooked up my AutoXray and didn't find any trouble codes. It indicated a very low voltage on the O2, 17 mV. I believe that does mean running very lean or too much oxygen in exhaust. I didn't see any values for the MAF and the MAT indicates -40. Does the ALDL provide this info or only OBD2 has this provision.
Could this also mean some injectors are not working porperly?
Thanks for all the pointers.
Old Apr 15, 2004 | 04:23 PM
Skippy Stone
The ALDL provides that info. If you suspect the injector, do you have a fuel pressure gauge and a injector tester? (This just pulses on one injector at a time.) Make sure that auto Xray is set to the right car. I once started to do a tune on the vette and realized I had it set for my wife's cadillac. Doh!
Old Apr 22, 2004 | 03:33 PM
JDANNER's Avatar
JDANNER
I'll be honest and tell you I'm no expert but I tried to pass inspection and failed with NOx off the chart. That's because I was using gutted Cats. With normal Cats passed with flying colors. Maybe your Cats are bad or O2 sensors need replacing. Good luck.
Old Apr 30, 2004 | 01:29 PM
vettenut67's Avatar
vettenut67
6th Gear
NOx is heat and GM used egr valves to control NOx and also camshaft over lap.
Make sure your egr system is working,also if you run higher octane fuel it will have a cooling effect and lower the NOx output.
Old Jun 1, 2004 | 12:46 PM
ir0nmaiden420's Avatar
ir0nmaiden420
From: Sarcasm. Just one of the many services I offer.
Try this. Run the car until the tank is almost empty. Right before the test pour a bottle of rubbing alchol in your tank. It always seems to work for me...matter of fact I did it a week ago on my 86.
To Failed Emission's Test
