LT1 vs LT4 - differences
Old Apr 13, 2004 | 09:06 PM
aeronautica86's Avatar
aeronautica86
Default LT1 vs LT4 - differences
What **exactly** are the internal differences between the LT1 and LT4 engines? How about the transmissions - were different gears offered for the two engines?
Old Apr 13, 2004 | 09:56 PM
tobijohn's Avatar
tobijohn
Bench Racer
St. Jude '03 thru 14,'25
Default Re: LT1 vs LT4 - differences (aeronautica86)
This link is a start:
http://www.malcams.com/legacy/misc/LT4.htm
Old Apr 13, 2004 | 10:00 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I'm not sure about the gearing but the main differences are that the heads and intake flow better on an LT4. The stock LT4 cam has slightly less lift than the LT1 but that is compensated for by the 1.6 rocker arms. I think duration is about the same if not identical. Slightly more compression in the LT4 as well but I'm not sure if it's because of chamber size or pistons.
Old Apr 13, 2004 | 10:16 PM
aeronautica86
Ok, well that helps alot. Basically what I'm trying to find out is if a modded LT1 and a modded LT4 will end up about the same in terms of rwhp and straight line performance...
Old Apr 14, 2004 | 11:19 AM
Shriker's Avatar
Shriker
If you are going to keep the engine intact (except maybe intake and cam), the LT4 is better because the heads are much better stock v. stock.
If , however , you are going at least with heads worked , I would go LT1 . I got an LT4 because I started out thinking I would keep the long block stock. But as usual, I ended up going heads cam. I could have gotten the same performance from a cheaper 95 LT1 instead.
Ultimately , LT4 heads flow better but the difference when they are fully worked compared to LT1 heads is not huge. We are talking about 20-30 rwhp on a 450-500 rwhp 396 solid roller stroker .
Old Apr 14, 2004 | 11:24 AM
vader86's Avatar
vader86
They can be made to do so, though for extremely serious combinations you would prefer the LT4 heads. Thats the only ultimate difference.
Old Apr 14, 2004 | 05:25 PM
aeronautica86
So basically the differences would be with the heads and roller rockers....would it be cheaper to buy an LT1 do all the bolt ons (intake, TB, headers, sport cats, cat - back etc) then port the heads and put in LT4 injectors and roller rockers, and a new cam, or just buy the LT4 and do the previously mentioned bolt ons? (ie, how much is the price diff in the cars, and how much do those internal mods to the LT1 cost?)
Old Apr 14, 2004 | 05:53 PM
tobijohn's Avatar
tobijohn
Bench Racer
I asked the same question regarding the LT1/LT4 price differential last June when I was looking. The post follows but keep in mind that with the passage of time, the price spread will narrow somewhat:
http://forums.corvetteforum.com/zerothread?id=574679
Old Apr 14, 2004 | 06:33 PM
Gary04Z06's Avatar
Gary04Z06
Default Re: LT1 vs LT4 - differences (tobijohn)
Here is a side-by-side comparioson chart: http://corvetteactioncenter.com/specs/1996/lt1lt4.html
Old Apr 14, 2004 | 06:43 PM
VAHROOM's Avatar
VAHROOM
Default Re: LT1 vs LT4 - differences (Gary96LT4)
I wonder if in the future the LT-4 will be worth more. It is an engine that was only made one year. Could this help resale values or am I just doing a little wishful thinking?
Old Apr 14, 2004 | 08:38 PM
vader86's Avatar
vader86
Default Re: LT1 vs LT4 - differences (VAHROOM)
I dont think it will be, not that much, but the Grand Sport probably will.
Old Apr 14, 2004 | 09:25 PM
eschoendorff's Avatar
eschoendorff
St. Jude Donor '08
I would think that the LT4 would lend some special value. It was only offered for one year, and even then it wasn't put into every Corvette. That and the fact that many consider it the final evolution of the original Chevy smally block design should make it appealing to future buyers. Disclaimer: JMHO ;)
To LT1 vs LT4 - differences
