FAN1 vs FAN2?
Old Apr 14, 2004 | 12:54 PM
gbody5's Avatar
gbody5
Default FAN1 vs FAN2?
I see these in Tuner Pro, what's the difference?
Thanks,
Old Apr 14, 2004 | 01:22 PM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
Default Re: FAN1 vs FAN2? (gbody5)
Fan 1 is the fan behind your radiator OR the LEFT/Drivers side fan if both are mounted behind the radiator.
Fan 1 comes on FIRST when the engine temp gets to the Fan 1 turn on temp.
Fan 2 comes on if Fan 1 doesn't provide enough cooling to keep the engine temp from getting to the Fan 2 turn on temp.
Hope I didn't confuse you. I think I did me.
Old Apr 14, 2004 | 01:31 PM
gbody5's Avatar
gbody5
Default Re: FAN1 vs FAN2? (VetNutJim)
I thought the Aux fan (FAN2) in front was controlled by a switch in the cyl head. Is this parameter just not used in my application?
Old Apr 15, 2004 | 12:04 PM
XTwinTurbo's Avatar
XTwinTurbo
Depends on the year of the Vette. I believe on 94+ Vettes both fans are controlled via the ECM programming. On older Vettes only one fan is controlled by computer the other uses the temp switch.
Old Apr 15, 2004 | 01:28 PM
Skippy Stone's Avatar
Skippy Stone
Default Re: FAN1 vs FAN2? (XTwinTurbo)
My 90 is ECM controlled. What is the broadcast code on your ECM? Someone here has a match, I am sure. If it has a second fan thermostat, it should be on the engine left side between cyl 1&3.
Old Apr 15, 2004 | 01:41 PM
gbody5's Avatar
gbody5
Default Re: FAN1 vs FAN2? (Skippy Stone)
I'll get into my ECM tonight to see what broadcast code I have. I did notice via a different .ecu file that the same parameters were differentiated by whether the A/C was off or on.
Thanks,
To FAN1 vs FAN2?
