89 avg./inst. fuel reading
Old Apr 14, 2004 | 05:07 PM
rwalshe's Avatar
rwalshe
1st Gear
Default 89 avg./inst. fuel reading
My 89's instant and average fuel rate is not working. Does anyone have any ideas what I should look for? :nonod:
Old Apr 14, 2004 | 05:25 PM
bogus's Avatar
bogus
Default Re: 89 avg./inst. fuel reading (rwalshe)
that data comes from the ECU/CCM... I don't remember the specifics, but if you ain't getting it, it's a problem there.
Old Apr 15, 2004 | 12:24 AM
SunCr's Avatar
SunCr
Info is on the serial data line from the ECM to the dash. That line is also spliced to the diagnostic connector. To see if it's the ECM, ground the connector and see if the Check Engine Light will flash a code 12. If so, the ECM is probably ok and the problem is in the splice to the dash or the dash itself. If it won't flash a code 12, the ECM is usually the culprit.
To 89 avg./inst. fuel reading
