Timing Chain Decision Cloyes or GM Extreme Duty Help I need to decide!!!
Old 04-14-2004, 07:53 PM
LT4BUD
LT4BUD's Avatar
Default Timing Chain Decision Cloyes or GM Extreme Duty Help I need to decide!!!
OK so I was planning on reusing my LT4 timing chain, but with the cam in place and new heavier valve springs I have decided at the last minute I need to upgrade or least go with new chain.
So I figure the GM Extreme Duty at Summit for $239 is way to go EXCEPT it is on back order for about 9 more days.
Summit cross referenced to Cloyes CLO-9-3151 which shows as a replacement for LT1/LT4 at $343. I also found on my own a Cloyes CLO-9-9100 which is described as heavy duty LT1, also $343.
So Cloyes is $110 more, but it is available now, about 1/2 hour away.
So what do I do, buy one of the two Cloyes, if so which one. Are they better than the GM or just more money. I still might find the GM unit at Pace or somewhere else, but just not sure which way to go now.
Help!!!
Old 04-14-2004, 07:58 PM
LT-4 CE
LT-4 CE's Avatar
Location: Everyday you must choose between the pain of discipline and the pain of regret. Fredericktown, OH
Default Re: Timing Chain Decision Cloyes or GM Extreme Duty Help I need to decide!!! (LT4BUD)
Bud, I always used Cloyes double roller timing chains in all my past motors - including the few 406s I raced. I NEVER had any problems what so ever.
I am not familiar with the GM product or if Cloyes makes one for our motors, but in my car, I'd use Cloyes.
Old 04-14-2004, 08:05 PM
LT4BUD
LT4BUD's Avatar
Default Re: Timing Chain Decision Cloyes or GM Extreme Duty Help I need to decide!!! (LT-4 CE)
Apparently Cloyes doesn't have a website, I am trying to figure out what the two chain sets are that Summit has in stock...?? Worth the plus $100 if so which one of the two??
Thanks Chris
CLO-9-3151 Original True timing set,Chevy 1/2in pitch LT1,LT4,L99 1995-up $343.39 $343.39
CLO-9-9100 Timing Set "Heavy Duty" SB Chevy "LT-1" $343.39 $343.39
This is what I find from Summit
[Modified by LT4BUD, 7:07 PM 4/14/2004]
Old 04-14-2004, 08:16 PM
STL94LT1
STL94LT1's Avatar
My understanding is that Cloyes makes the GMPP extreme duty timing set.
Have you tried to call Chris at Superior to see if they have the extreme duty in stock?
Old 04-14-2004, 08:24 PM
Corvette Kid
Large Impressive Member
Support Corvetteforum!
Corvette Kid's Avatar
Location: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Default Re: Timing Chain Decision Cloyes or GM Extreme Duty Help I need to decide!!! (STL94LT1)
Why not go with a Meziere pump for a bit over $200 then you can go with a 3145 Cloyes (reg, SBC type) for about $80. Plus pick up a few free ponies with less engine drag.
Old 04-14-2004, 09:28 PM
LT4BUD
LT4BUD's Avatar
Default Re: Timing Chain Decision Cloyes or GM Extreme Duty Help I need to decide!!! (Corvette Kid NC)
The water pump is already part of my upgrade.
Old 04-14-2004, 09:46 PM
joeveto
joeveto's Avatar
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Contributor
Can't help you with the decision, but my dad lives in Hinkley. Nice to see a neighbor. Kind of... :seeya
Old 04-14-2004, 10:00 PM
Corvette Kid
If that's the case then you have no need for those expensive LT1-4 specific timing sets. A regular small block double roller will work great for a fraction of the cost. It's what I run. I'm pretty sure that's the right number I gave you earlier. Someone will verify I hope.
Old 04-14-2004, 10:10 PM
LT4BUD
LT4BUD's Avatar
Corvette Kid NC, thanks for help
I found Cloyes site, it is somewhat helpful
9-3145 is original True for 1985 up sb with factory roller cam. 9-3151 is same for LT1 and 9-3150 is same for LT4. All are $343 at Summit
I can not believe it, Summit doesn't carry 9-3150, guess that is why they said 9-3151 which they do carry
Old 04-14-2004, 10:30 PM
No Go
No Go's Avatar
Chris at Superior probably has the chain in stock...my cost just a month or two ago was $233.
Cloyes does make the GMPP part...talked with Cloyes directly for this info...
Old 04-14-2004, 10:38 PM
Corvette Kid
Something's wrong here. I just went out in the garage and looked at the box mine came in and it is indeed a 9-3145. But I only paid $90 for it at my local speed shop just a couple of months ago and I've seen them even cheaper online. I've got to check this out!
Old 04-14-2004, 10:45 PM
Corvette Kid
Just checked Summit's site, hope this link works.
http://store.summitracing.com/defaul...oyes&x=17&y=12
$79.95 is the price I saw.
Yes, it worked. Go to page 4.
[Modified by Corvette Kid NC, 10:46 PM 4/14/2004]
Nathan Plemons
Nathan Plemons's Avatar
I've got the Cloyes True Double Roller timing chain on mine, cost me about $70. I bought it used from a forum member (used, being he put it on the car but never ran it)
You can buy this chain brand new from Jegs for $79.99, I'm sure Summit has it even cheaper. Jegs part number is 220-9-3145
Old 04-14-2004, 10:54 PM
Corvette Kid
Default Re: Timing Chain Decision Cloyes or GM Extreme Duty Help I need to decide!!! (Nathan Plemons)
BTW, you'll have to plug the pump drive hole in your timing cover. Some people have them welded shut. I didn't want to do that but couldn't find a core plug to fit the odd size. I used JB Weld and plugged it with a half dollar. I turned it to where the eagle shows because I couldn't have a Democrat's face on my car........... :lol:
Old 04-15-2004, 08:06 AM
Nathan Plemons
I bought a spare cover and had it welded up, then powder coated. Looks like it was supposed to be that way.
Old 04-15-2004, 08:13 AM
LT4BUD
LT4BUD's Avatar
OK I am really confused now. You are right, but scroll down the page to the 9-3151 for LT1/LT4, it is $343.
What is the difference?????
Old 04-15-2004, 08:45 AM
Nathan Plemons
The one specifically for the LT1/LT4 will retain the provision for driving the mechanical water pump, which you don't need if you're going electric.
To Timing Chain Decision Cloyes or GM Extreme Duty Help I need to decide!!!
Old 04-15-2004, 08:52 AM
LT4BUD
LT4BUD's Avatar
That is worth $260????
That is nuts!!!! But I have seen stupider things
Also it turns out, per Summit, that Cloyes no longer makes the 9-3150 for LT4, but just the 9-3151 to be used for both.
Sounds like what I really need is the 9-3145
Thanks Nathan
Old 04-15-2004, 08:53 AM
Nathan Plemons
Nope, but that's what they sell it for!
Old 04-15-2004, 01:17 PM
96GS#007
96GS#007's Avatar
Received 1,777 Likes on 1,068 Posts
Keep in mind that typically in order to use the cheaper (cost wise) timing chains you either have to custom machine the crankshaft reluctor ring or remove the crankshaft reluctor ring. The reluctor ring is unique to '96 LT1/4 OBD II cars.
Quick Reply: Timing Chain Decision Cloyes or GM Extreme Duty Help I need to decide!!!
