Spec needed: stock rear spring bolt length
Old Apr 14, 2004 | 09:45 PM
TomH91's Avatar
TomH91
Default Spec needed: stock rear spring bolt length
Could anyone tell me the length of the stock rear spring bolts? Do the aftermarket lowering bolts typically have the drilled hole for the cotter pin like the stockers? How much shorter/longer are most lowering bolts, and how are they different?
I know you can just remove the cotter and crank the nut down on the stock bolts, but I don't want to do that for resons of safety. I'd appreciate any info. :)
Old Apr 14, 2004 | 11:36 PM
bogus's Avatar
bogus
Default Re: Spec needed: stock rear spring bolt length (TomH91)
TTT... I didn't measure mine... sorry.
Old Apr 14, 2004 | 11:40 PM
Raistlin's Avatar
Raistlin
Stock hex head cap screws:
14mm(D) x 2.0 x 230mm(L) grade 9.8 (min tensile strength 130,500psi)
they are equivalent to SAE --
9/16" x 9" grade 6 (min tensile strength 133,000psi) or grade 8 (min tensile strength 150,000psi)
Old Apr 14, 2004 | 11:57 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Default Re: Spec needed: stock rear spring bolt length (Raistlin)
I knew once but forgot. I thought it was in the 8 to 10 inch range. If you lengthen one inch you get an inch of lowering and so on, is that correct?
Old Apr 16, 2004 | 12:08 AM
TomH91's Avatar
TomH91
Hmm...I'd swear the stock bolt took a 21mm socket the other night. Maybe I mis-remember. Thanks for the info, though.
Old Apr 16, 2004 | 06:10 AM
Steel Blue 91's Avatar
Steel Blue 91
I believe he's refering to the thread size and not the head size.
Old Apr 16, 2004 | 08:29 PM
Raistlin's Avatar
Raistlin
Default Re: Spec needed: stock rear spring bolt length (Steel Blue 91)
sorry if that was confusing to anyone...
stock bolts have a diameter of 14mm, length of 230mm and the thread pitch is 2.0
diameter is mearsured at the shank, not the head. i don't recall what diameter the head of the bolts are.
divide by 25.4 to get measurements in inches
[Modified by Raistlin, 8:30 PM 4/16/2004]
Old Apr 17, 2004 | 12:58 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
The stock bolt from my 86 coupe is 9.25" overall, with the cotter pin hole at 8.25". The MAD Lowering bolt is 10.5"
-JRC-
To Spec needed: stock rear spring bolt length
