94 lt1 backfires when in closed loop intermittently
Old Apr 14, 2004 | 11:17 PM
jpslt1's Avatar
jpslt1
Default 94 lt1 backfires when in closed loop intermittently
hello, just bought a 94lt1 with 70,000 miles,but i have problems. when corvette is started cold runs great until it goes into closed loop. then it intermittently backfires through the intake from a stop. things i have tested engine vaccuum 21 inches at idle,fuel pressure 40psi . replaced plugs and wires flushed injectors sprayed carb clean around intake no leaks noticeable . tested injector resistance hot and cold 11.9-12.3 ohms . no check engine light on any help would be greatly appreciated
:cheers:
Old Apr 14, 2004 | 11:33 PM
bogus's Avatar
bogus
Default Re: 94 lt1 backfires when in closed loop intermittently (jpslt1)
that sounds a lot like the opti failing...
Old Apr 14, 2004 | 11:38 PM
jpslt1's Avatar
jpslt1
Default Re: 94 lt1 backfires when in closed loop intermittently (bogus)
i was wondering about that maybe crossfiring in the cap
Old Apr 15, 2004 | 10:58 AM
John Row's Avatar
John Row
:iagree: 60K is about a nomal lower limit on the Opti. Some get lucky and make it over 100K, but that's pretty rare. Check your water pump weep hole.
BTW: Welcome to the Forum.
[Modified by John Row, 7:59 AM 4/15/2004]
Old Apr 15, 2004 | 10:19 PM
jpslt1's Avatar
jpslt1
Default Re: 94 lt1 backfires when in closed loop intermittently (John Row)
thanks for the information :cheers: im getting a new optispark thanks :thumbs:
Old Apr 15, 2004 | 10:43 PM
crheinish's Avatar
crheinish
Bad coolant temp sensor. Located in water pump. :cheers:
Old Apr 15, 2004 | 10:59 PM
jpslt1's Avatar
jpslt1
Default Re: 94 lt1 backfires when in closed loop intermittently (crheinish)
how would i go about testing the sensor ohm meter and what values would be okay .isnt there two sensors on the pump :smash:
To 94 lt1 backfires when in closed loop intermittently
