opti-spark distributor cap removal how?
Old Apr 16, 2004 | 10:52 AM
boonie2's Avatar
boonie2
Default opti-spark distributor cap removal how?
How do i remove or seperate the opti-spark distributor cap from the rest of the unit? what tools do i need to remove those micro bolts holding the distributor cap assembly together?
thanks boonie
Old Apr 16, 2004 | 11:09 AM
bogus's Avatar
bogus
Default Re: opti-spark distributor cap removal how? (boonie2)
They are safety, or tamper proof, Torx screws.
You can get a set of 1/4" drive bits from a parts store rather cheaply.
Old Apr 16, 2004 | 12:24 PM
comp94's Avatar
comp94
to seperate the cap from the rest of the assy you will need a E-5 inverted torx bit. you will not be able to find one in sears, autozone, nappa, home depot, or a local hardware store. you have one of two choices either get one from snap-on or make one. both time that i change my cap and rotor i made my own out of a small section of break line. i took one of the new screw that the cap and rotor kit came with and put it in a vise (surrounding in brass so that i wouldn't damage the threads) with the head facing up. i then took the small section of break line (i forgot the size that i used) and put the flared end over the head of the screw and tapped the other end with a hammer until it could not be tapped down onto the screw anymore. take it off and, walla, a E5 inverted torxs bit that you paid $2.00 for instead of paying $20.00. you just cant abuse it too much because it is after all break line.
Old Apr 16, 2004 | 01:06 PM
bogus's Avatar
bogus
Default Re: opti-spark distributor cap removal how? (comp94)
isn't that the same as the torx with the hole in it? A safety torx... it has been so long since I did mine... 3+ years, now!
Old Apr 16, 2004 | 04:25 PM
John Row's Avatar
John Row
I bought a set of the E- bits at Kragen's ~$14.
Old Apr 21, 2004 | 12:27 AM
comp94's Avatar
comp94
Default Re: opti-spark distributor cap removal how? (bogus)
no its just a backwards torx bit
Old Apr 21, 2004 | 12:54 AM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
I got mine off with a regular socket.
I forget what size, but it worked.
Old Apr 21, 2004 | 08:18 AM
bogus's Avatar
bogus
Default Re: opti-spark distributor cap removal how? (BrianCunningham)
yea, a 12 point socket would easily grab an inverted torx....
sorry, gang, got myself confused on all the variances in torx screws!
Old Apr 21, 2004 | 09:18 AM
DRAGRACR's Avatar
DRAGRACR
one of the torx screws that comes out of the plate on top of the throttle body works well. I took one out of an old throttlebody and chucked it up in a drill. Worked fine for me. :cheers:
Old Apr 21, 2004 | 10:03 AM
comp94's Avatar
comp94
Default Re: opti-spark distributor cap removal how? (DRAGRACR)
i tried to find a tox screw to do the same thing........i didn't even think about using one from the car. good tip this one is on me :cheers:
[Modified by comp94, 3:04 PM 4/21/2004]
Old Apr 21, 2004 | 12:52 PM
DRAGRACR's Avatar
DRAGRACR
Glad to help! :cheers:
Old Feb 2, 2017 | 09:50 PM
icanjuggle@yahoo.com's Avatar
Cruising
Default Proper torx socket to remove optispark cap
I just removed the factory cap on my 94 c4 optispark... it is DEFINITELY an E4 Torx Socket
Old Feb 3, 2017 | 05:02 AM
antfarmer2's Avatar
antfarmer2
I hope they figured this out in the last 14 years. Locktight the cap and rotor.
Old Feb 3, 2017 | 09:55 AM
Tact's Avatar
Tact
Former Law Dawg Moderator
CF St. Jude Co-Organizer
St. Jude Donor '05 thru '24
13 yo thread...
To opti-spark distributor cap removal how?
