94 SYS again.
Old Apr 16, 2004 | 11:08 AM
Sullys Vette's Avatar
Sullys Vette
Default 94 SYS again.
What ohm&watt resisters to use for 94 LT1.
Old Apr 16, 2004 | 06:20 PM
69mako's Avatar
69mako
Default Re: 94 SYS again. (Sullys Vette)
Where.....???? whats the problem?
Old Apr 16, 2004 | 07:46 PM
Sullys Vette
Default Re: 94 SYS again. (69mako)
SYS flashing 3 times on left side of fuel guage. It comes and goes. New battery. I just had an aftermarket radio installed. Need to fix? HOW!
Old Apr 16, 2004 | 08:53 PM
69mako's Avatar
69mako
Sounds like they screwed something up...maybe stuck two wires together and it causing a ground.
It started "RIGHT" after the instal?
Old Apr 17, 2004 | 10:42 AM
Sullys Vette
It is probably the after maket radio. I'm going back to the stero shop today and tell them about those resisters I read in other forums.
Old Apr 17, 2004 | 11:02 AM
JB666's Avatar
JB666
Hey, this is odd.. Mine too! (I have a similar thread open right now). Right after install of aftermarket system, SYS is flashing 3X on startup.. They killed my battery though when they were putting the system in, so the general opinion is that it's that... :confused:
Old Apr 18, 2004 | 10:28 AM
69mako's Avatar
69mako
Default Re: 94 SYS again. (JB666)
"They suck at installing after market sound systems in Vettes"
Old Apr 18, 2004 | 10:42 AM
Ramrod92's Avatar
Ramrod92
Cruise-In II Veteran
SYS flashing on the dash is an indication that the CCM has detected an error in one of the electrical curcuits. One of the most common is when a battery is going bad and the CCM sees voltage below a set level (I think about 10 volts) for a set amount of time. If you have installed an aftermarket radio then the CCM is probably detecting an error in the dimmer curcuit. Here's the TSB for that http://www.corvetteforum.net/c4/dave8476/index4.shtml :steering:
Old Apr 18, 2004 | 10:47 AM
JB666's Avatar
JB666
Default Re: 94 SYS again. (Ramrod92)
Thanks!! I printed that out, and will bring it to the shop on Tuesday!! That little flashing SYS is starting to drive me crazy!! Plus, while I'm driving, the screensaver on the deck keeps going from single color, to flashing bright, and having the backlight(colors) on, I've been wondering why!!
:crazy:
Old Apr 18, 2004 | 01:04 PM
Sullys Vette
I had the stereo shop install those resisters. ITS A BEAUTY NOW. THANKS :) :) :)
To 94 SYS again.
