Is your Cruise not working. Possible simple fix.
Old Apr 16, 2004 | 07:29 PM
R23HTC's Avatar
R23HTC
Default Is your Cruise not working. Possible simple fix.
My cruise decided to quit. After talking to my local mechanic he didn’t think it was the servo. He said they rarely go out. He did a little checking and said the servo wasn’t getting any power at all. He thought it might be in the switch on the turn signal. After getting a price quote I decided to leave it for a while. Well today I starting thinking about the time I had all those problems with the brake lights staying on. The switch was very difficult to get adjusted properly. That got me to thinking that I may now have a similar problem with the switch on the brake or clutch for the cruise control. I dropped the hush panel from under the steering column and decide to see what I could find. I unplugged the switch on the clutch and hooked a meter up to it while the car was running and with the cruise switched to on. I didn’t have any continuity with the clutch pedal at rest or when I pushed it down, but if I pull ever so slightly back on it………BINGO!!!!!! So after pushing the switch a notch forward and rechecking the continuity everything seem to be in order. Took it out for a road test and Yippee! the cruise is operational again. Might be something to check into for those of you with non-working cruise as it’s not that difficult to fix and it costs only a little time. :yesnod:
:party:
Old Apr 16, 2004 | 07:34 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Is your Cruise not working. Possible simple fix. (R94 LT 1)
Nice piece of work. :cheers:
On an A4 I believe there is a similar curise disengage switch on the brake pedal.
Old Apr 16, 2004 | 07:37 PM
R23HTC's Avatar
R23HTC
Default Re: Is your Cruise not working. Possible simple fix. (65Z01)
There probably is, but on the 6spd there is 2. One for the brake AND one for the clutch. You have to check both.
Old Apr 16, 2004 | 08:15 PM
JAKE's Avatar
JAKE
I just did the same thing to mine a couple of days ago after I installed a new cruise control servo. The rubber on my servo was torn so I needed another one.
I looked up the adjustment procedure in the GM Shop Manual and it directed me to depress the brake pedal fully; then while holding it depressed, push the switch forward as far as I can. Then release the brake pedal and pull the brake pedal rearward as far as possible to properly adjust the switch location.
As you said "BINGO!".
Jake
Old Apr 16, 2004 | 09:11 PM
xs650's Avatar
xs650
Good tip, I've had the same problem on a Toyota and a GMC pickup, except it was the brake pedal switches.
Old Apr 16, 2004 | 10:40 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Simple fix on my 87. A mousie had chewed through the vacumn line that ran to the accumulator. I cut off the bad end and pulled out the slack and reconnected it. WOW - it worked! The accumulator is located down by the left cornering light and looks like a round black plastic ball. :smash:
Old Apr 17, 2004 | 06:43 AM
86PACER's Avatar
86PACER
:party:
Old Apr 17, 2004 | 08:34 AM
no_radio's Avatar
no_radio
Default Re: Is your Cruise not working. Possible simple fix. (86PACER)
While we're posting quick fixes to cruise...
There are some vacuum lines that run near or below the battery area. On my dad's '86 all I had to do was replace the lines that had been damaged by battery acid sometime in the past.
Cost about $5.
Jeff
Old Apr 17, 2004 | 09:13 AM
R23HTC's Avatar
R23HTC
Default Re: Is your Cruise not working. Possible simple fix. (no_radio)
Cost about $5.
Jeff
Good point. If you've ever jump started a dead battery and then the cruise stopped working you probably knocked one of them loose off the servo. Ask me how I know. :rolleyes:
Old Apr 17, 2004 | 03:08 PM
sraft's Avatar
sraft
I went through the same gyrations before I discovered that the brake/vacuum switches were the culprit. Sometime around '92/'93 GM changed the bracket/retainer that holds these switches from metal to plastic. This plastic retainer is prone to failure. The part (3537079) is ~$7 from the dealer.
Old Apr 18, 2004 | 12:54 AM
stalkervette's Avatar
stalkervette
Default Re: Is your Cruise not working. Possible simple fix. (sraft)
Are these fixes good for an 85? Mine doesn't work and i haven't had time to check. Glad to hear alot of you are getting it fixed, hope mine does. :thumbs:
Old Apr 18, 2004 | 02:35 AM
R23HTC's Avatar
R23HTC
Default Re: Is your Cruise not working. Possible simple fix. (stalkervette)
I don't know, but it wouldn't cost you anything but time to check.
Old Apr 18, 2004 | 09:20 AM
KY Vette's Avatar
KY Vette
Quick fixes, mine was easier than any of these, once I found it. The day I bought my Corvette, the cruise quit working on the way home, when I hit a bump.
There's a spring clip that connects the linkage at the vacuum advance, my clip had fallen off. It cost me 8 cents for a new one. :D
[Modified by KY Vette, 8:23 AM 4/18/2004]
Old Apr 18, 2004 | 02:03 PM
TIMSPEED's Avatar
TIMSPEED
Default Re: Is your Cruise not working. Possible simple fix. (KY Vette)
My CC works...but the thing it does, is if I set it, then use the switch on the turn signal to up my CC speed (say I wanna go from 60mph up to 65mph) it kicks it off. Dunno why..it's like the "Accel" portion does just that, speeds up, but doesn't reset the CC at the new speed.
Old Apr 18, 2004 | 02:10 PM
JF_AH_64's Avatar
JF_AH_64
I had the same problem after I changed the brake booster in mine. Isn't it nice when the solution costs you nothing.
Old Apr 21, 2004 | 06:23 PM
R23HTC's Avatar
R23HTC
Default Re: Is your Cruise not working. Possible simple fix. (JF_AH_64)
Tell me about it. Thought for sure I was going to need a $225 servo! :eek:
Old Apr 21, 2004 | 08:30 PM
MostWanted's Avatar
MostWanted
Anyone ever have to buy the wires and harness that goe to the CC in the engine compartment? My wires were cut when I bought it.
To Is your Cruise not working. Possible simple fix.
Old Apr 21, 2004 | 09:26 PM
Chris@SD's Avatar
Chris@SD
Nice job David! Keep this up and maybe you can join the Speed Demon team?!?! :reddevil
Old Apr 21, 2004 | 09:55 PM
R23HTC's Avatar
R23HTC
Default Re: Is your Cruise not working. Possible simple fix. (Chris@SpeedDemon)
Hey, I thought I was already part of the team! :D Nice to see ya posting in the C4 section again. :jester
[Modified by R94 LT 1, 8:56 PM 4/21/2004]
Old Apr 21, 2004 | 11:34 PM
Chris@SD's Avatar
Chris@SD
Definitly part of the team! :smash:
I still lurk in here, but every time I post I don't seem to be welcome. :cry
