PKE problem 1996
Old Apr 19, 2004 | 01:23 AM
larryfs's Avatar
larryfs
Default PKE problem 1996
if I have the PKE turn on, it works fine. If I shut it off, then try to use the remote, only the passenger door works. the drivers door doesn't unlock.
too strange, but I had to turn the PKE back on until I figure out why this happens. anybody familiar with PKE problems?
Old Apr 19, 2004 | 03:40 AM
JasonL's Avatar
JasonL
Default Re: PKE problem 1996 (larryfs)
That's normal behavior. Just a stupid design.
Old Apr 19, 2004 | 06:40 AM
Torquem's Avatar
Torquem
Default Re: PKE problem 1996 (JasonL)
put the key in the ignition and push and hold the button like you are trying to turn it off. This will make it work both doors.
Old Apr 19, 2004 | 10:47 AM
Red Dwarf's Avatar
Red Dwarf
Default Re: PKE problem 1996 (Torquem)
That' only works if the system is active.
To PKE problem 1996
