5 points - mounting ?
Old Apr 19, 2004 | 02:47 PM
larryfs's Avatar
larryfs
Default 5 points - mounting ?
for those of you that have 5 point harnesses.
where did you mount the lap belts?
I want to retain the factory belts.
did you mount them under the factory belts, or get the clip on simpson belts that clip onto an eyehook?
I want to easiest mounting where I can retain the factory belt operation.
Old Apr 19, 2004 | 05:36 PM
ffvetteman's Avatar
ffvetteman
Default Re: 5 points - mounting ? (larryfs)
:lurk:
me too...
Old Apr 19, 2004 | 07:35 PM
STL94LT1's Avatar
STL94LT1
R-D Racing sells a lap belt mounting kit that allows both factory belts and 5 pt lap belts to be used together.
Old Apr 20, 2004 | 12:17 AM
Gary04Z06's Avatar
Gary04Z06
Default Re: 5 points - mounting ? (STL94LT1)
:iagree: http://www.r-dracing.com
Old Apr 20, 2004 | 06:42 PM
96CollectorSport's Avatar
96CollectorSport
From: If you don't weigh in you don't wrestle Road America
Default Re: 5 points - mounting ? (Gary96LT4)
I used the R&D system in my car here is what it looks like. The belts are in the way a little for normal driving but as long as your smart about putting the belts in you'll be O.K. Make sure you bring the lower adjusters up the belt before installing the seats or the seat won't go down. The directions given are very good and help you install everything fairly easily. :thumbs:
Old Apr 20, 2004 | 07:24 PM
McShagger's Avatar
McShagger
Default Re: 5 points - mounting ? (96CollectorSport)
Your picture isnt showing... Im looking to get a harness and would like to know what everyone recommends and where is a good place to get it.
[Modified by McShagger, 4:29 PM 4/20/2004]
To 5 points - mounting ?
