hmmmm.. Help please...
I took my 94 for a ride Sunday. It started acting up, momentarily cutting out at cruising speed after about 30 miles. Came to a stop, checked things out, and car ran poorly from idle to cruising speed (missfiring, etc). Decided not to risk it, so I turned and headed home. Seemed ok at 58 - 59 MPH, but anything over or under, the car was horrible, backfiring et al.
I noticed that the temp gauge, which has alwas been solid at 185, was a bit over. When I was about 2 miles from home, I had to stop for a red light. The car felt like it was running on 2 cylinders and it did have all it could do to get up the hill toward home.
I started it Monday AM, and it ran super while cold. I know if it approached 185 degrees again it would start acting up.
Does this sound like Opti? It was replace shortly before I got it. I see no evidence of any coolant leakage.
Any input is appreciated....
Thanks!
1) is it setting a code?
If not, I would check the fuel filter and/or the coil wire. Also, I suspect the car has been in storage, did you add a fuel stabilizer? If not, the gas could be bad... if you did, there could still be water in the tank. Add some dry-gas.
2) if it is, determine what the code is.
A big suspect for this kinda problem would be the MAF...
You see, the IAC does not do anything after the engine passes about 1100rpm or so... I don't remember exactly where, but it's name is IDLE Air Control... not RUNNING Air Control! :thumbs:
I don't honestly think it's the opti. When they fail, they do it gradually.
If I recall it started this at the end of last fall while still in regular use, just gotten much much worse now.
Thanks!
It's just a thought, and it may not explain the backfiring and so on but thought I'd mention it as it's so easy to check.
good luck
S'nut
