opinions needed
Old Apr 20, 2004 | 05:28 PM
Gogobig92's Avatar
Gogobig92
Default opinions needed
will be done my 92vette by sept.04 heres what it has tell me how fast you think it`ll go its a 92 with a 4link 9in rear aluminum center with a spool 4.30 gears,strange 35 spine axles, M/T 28x13.5s on weld alumnastars, 26x4s on front with alumnastars,cromoly10 pt. cage, parachute, wheely bars, kirkey aluminum seats, as for engine I am having a 415 ci. smallblk bowtie blk, crower crank,carillo rods,jesel belt timing, jesel shaft rockers, comp cams solid roller custom grind, dart 220 heads cnc`d with 2.100 in & 1.625 ex titanium on intake side and inconel exaust, also a rev kit on the valvetrain, dart intake and a 1090 king demon carb, 2in primary stahl headers ,ati trans with an 8in 4500 converter how fast you think, car w/o driver 2980lbs roughly
Old Apr 20, 2004 | 07:36 PM
redfast's Avatar
redfast
Default Re: opinions needed (Gogobig92)
Sounds slow. :jester Don't know
Old Apr 20, 2004 | 07:57 PM
CFI-EFI's Avatar
CFI-EFI
Mid 14's
Old Apr 20, 2004 | 08:02 PM
TA's Avatar
TA
Default Re: opinions needed (CFI-EFI)
Mid 14's
It might break into the upper 13s :jester
Old Apr 21, 2004 | 05:29 PM
JAKE's Avatar
JAKE
Should run at least mid 10s.
Jake
Old Apr 21, 2004 | 10:57 PM
SPEED750's Avatar
SPEED750
Default Re: opinions needed (JAKE)
PARACHUTE :lolg: Seems a bit optimistic for a small block. :auto:
Old Apr 22, 2004 | 06:15 PM
Gogobig92's Avatar
Gogobig92
Default Re: opinions needed (SPEED750)
small blocks will suprise you, the combination should make a little over 700hp.
Old Apr 22, 2004 | 06:19 PM
scorp508's Avatar
scorp508
If you've seen what the smallblock C5s have done lately you wouldn't have posted that.
Old Apr 22, 2004 | 06:21 PM
Gogobig92's Avatar
Gogobig92
parachute is for later, because I am going to put a 2 stage fogger on this motor, trying to get 8s on nitrous...
To opinions needed
