Steering Column 85'
Old Apr 20, 2004 | 05:48 PM
Cablexpert's Avatar
Cablexpert
2nd Gear
Default Steering Column 85'
Hi i'm new here and was wondering if anyone had the diagram of my column from the upper bearing to the horn contact...the prev. owner screwed up my Tele. lever and ran a bolt down into the shaft....i removed the short shaft w/the woodruff key in it ; re-tapped it and bought the correct bolt, but now i can't seem to keep the upper bearing tight...anyone got an 85' serv. manual?...wonderin if i'm puttin it back together in the right order...thanks ahead of time :seeya
Old Apr 21, 2004 | 03:57 PM
85blkZ51's Avatar
85blkZ51
Default Re: Steering Column 85' (Cablexpert)
Sorry to hear about your probs, I put a new horn button on my 85 but I dont have a manual and I've not been any deeper into the vettes column than that. I'm sure somebody else can chme in.
[Modified by 85blkZ51, 8:58 PM 4/21/2004]
Old Apr 21, 2004 | 05:15 PM
Cablexpert's Avatar
Cablexpert
2nd Gear
Thanks 85blk...i'm redoin the int. and was hopin to put off buyin a good manual but i might have to; i'm sure it won't go to waste.
To Steering Column 85'
