Some shop in Cali quoted 500 lbs with their "kit" but who knows what all that includes for a swap. I'm guessing that's not just the engine, but could be :lol:
Anyone know an approx. weight difference between the LS1 and the LT1?
There's only about 100lbs difference - believe it or not. All of the weight savings is in the block, since both engines have aluminum heads, composite intake, steel crank/con rods, alumimum pistons, and tubular headers.
From a weight point of view, it's alot of effort to save 100lbs. But when you figure that the LS1 has an immense performance potential, the effort may be worth it.
I doubt that 80 lbs is only equal to 1+/- horsepower. Remember that the general rule of thumb is for every 100 lbs you remove from a door car you will typically see a 1/10 reduction in your e.t. There are instances when you remove front end weight and gain even more benefit because it allows the car to weight transfer much quicker. Actually if you just move your current engine further back in a car (6-8 inches) it can make a big difference in how the balance of the car and how it transfers weight when you launch it.
corvetterromw: I like your idea and I have a 1984 so I do not have the LT1 or LT4 engine but I wanted to get an idea of weight savings. Swapping from my engine to either the LT1 or the LS1 will save me a bunch of weight. About a week ago I placed a post in the C4 parts for sale/wanted along with a few other racing sites hoping to locate a Dart, World, Donavon or Brodix block. You and I were thinking alike...the issue is the price of the block is $3,000-$4,000 and you can buy a used complete LS1 used for $3500+/- and I was just considering which might be the better way to go and before I made my final decision I wanted to make sure I would get the weight reduction from the LS1. :)
