Need Advice on Possible ASR/ABS Problem
Found a '93. Car is absolutely gorgeous but there are a few possible problems so I thought I'd see if anyone could give me some input or advice.
Car drives perfect, EXCEPT there is some weirdness with brakes in a couple of ways.
1) Pedal pulses even when applied lightly. I was under the impression that you should not feel this unless the ABS was being activated due to a "panic" type stop.
2) There's some "grinding / chatter" type sound from the rear that occurs after you come to a stop and then take off again.
3) Both the ARS, (even when the ARS is turned off), and ABS lights are lit up constantly. Based on what I've read, this seems to be a combined unit that controls both functions.
Also, only some of the functions work on the drivers power seat controls. No back and forth, no tilt. IÂ’m guessing the motors are O.K., so does this sound like a switch problem?
I really like the car, and if not for these glitches it would probably be mine tonight, but I'd wanted to see if I'm looking at a major problem or something that can be corrected without some obscene amount of money.
Any advice would be greatly appreciated.
[Modified by BankBoy, 9:25 PM 4/20/2004]
