'86 fuel lines, which is return/supply?
Old Apr 21, 2004 | 05:25 PM
FlyboyZR1's Avatar
FlyboyZR1
Default '86 fuel lines, which is return/supply?
Can anyone confirm for me which line is which?
The shop manual says the line near the hatch is the supply, and the line near the bumper is the return, however others have told me the opposite.
Which is which?
Old Apr 21, 2004 | 06:55 PM
JAKE's Avatar
JAKE
Default Re: '86 fuel lines, which is return/supply? (FlyboyZR1)
Which is which?
I don't understand your points of reference: hatch/bumper. Can you explain?
Jake
Old Apr 21, 2004 | 07:03 PM
JAKE's Avatar
JAKE
If you're referring to the lines right under the fuel filler door, according to the diagram in the Corvette Shop Manual for the 1986, the line that is the most forward is the FEED line (called the Fuel Feed Piep) and the one that is the most rearward is the RETURN line (called the Fuel Return Pipe.
Hope this is what you're referring to and that it helps.
Jake
Old Apr 21, 2004 | 07:04 PM
rons85's Avatar
rons85
You must be looking in from the top at the fuel filler neck and top ot the tank, with the gas door and rubber boot removed - right? If so, the top (closest to the hatch) hose - probably with Two hose clamps on it - is the pump out or pressure line. The bottom line going towards the passenger side, with one - probably - hose clamp on it is the fuel return line, and the bottom line going towards the Drivers side, with - probably - a spring clamp on it is the vent line.
Old Apr 21, 2004 | 07:24 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Default Re: '86 fuel lines, which is return/supply? (rons85)
:withstupid:
Old Apr 21, 2004 | 08:18 PM
FlyboyZR1's Avatar
FlyboyZR1
Thankyou! I actually just found it in the Haynes manual right before you typed this. :)
Old Apr 22, 2004 | 09:17 AM
Rich B.'s Avatar
Rich B.
WTF is that "Funtigo" crap doing taking up Troy's precious bandwidth??? :cuss
Either renew your subscription or take it out of your sig...Thankyouverymuch!... :thumbs:
Old Apr 22, 2004 | 12:18 PM
FlyboyZR1's Avatar
FlyboyZR1
Default Re: '86 fuel lines, which is return/supply? (Rich B.)
:lol:
haha I didn't even see that ... I was just desperate for a quick way to host a pic.
This thread is finished.
[Modified by FlyboyZR1, 11:19 AM 4/22/2004]
To '86 fuel lines, which is return/supply?
