Replacing Heater Core
Old Apr 21, 2004 | 06:00 PM
VetteBandit's Avatar
VetteBandit
Default Replacing Heater Core
Hey Guys,
I know there has been a few threads about changing the heater core out if you do the carpeting, to prevent later mess and :cuss . But I was looking through Chiltons last night, as Im getting ready to do this lil job, and it seems like no small replace. Im sure a bunch of you have done this before, I just wanted to get an idea of 1) How bad is it really? 2) How long did it take you to do? Thanks in advance! :auto:
Old Apr 21, 2004 | 06:06 PM
90Z51Vette's Avatar
90Z51Vette
Default Re: Replacing Heater Core (VetteBandit)
Step #1: Disassemble entire car.
Not quite that bad, but close. Took me two weekends. One of those jobs where I would find myself just staring at it at times...
Good luck,
Mark
Old Apr 21, 2004 | 06:50 PM
1MoorTym's Avatar
1MoorTym
I just finished doing my 89. I will say its a pia, but looking back at it, now that I'm done :D it wasn't that bad. I wrapped mine up in about 5-6 hours total.
Find the fastguy procedure and you'll be ok.
Old Apr 21, 2004 | 06:53 PM
rons85's Avatar
rons85
Well... It's not That bad. Certainly there are Easier cars to do it on, but there are harder too. One of the biggest pains on the 'vette is how low you have to get to do it - it helps to have the car on a lift where you can stand beside the open pass. door and work at chest height. If you don't have a lift handy then put the car on stands and work kneeling next to it. You wind up laying across the door sill somewhat either way, but it helps. In actual labor time - took me about 4 hours to get it all apart, another 4 or slightly less to get it back together. Do some homework up front and pick up a new plastic connector for the temperature control cable before you start - you'll probably break the old one-it's old and brittle! This is the clip that connects the end of the control cable to the arm on the temperature control door, it'll have to come from GM. I broke mine and spent at least an hour cobbing up something to work so I could keep putting it back together. It's still in there... Couple of other things (as I remember them - I replaced the core in mine about a year ago...) There are a couple of metal "clips" holding the core into the froward half of the heater housing (you only take out the Rear half of the housing thereby exposing the core). They come out ok, but are a real bear to get lined up going back in. Toughest part of the job. The foam seal that the pipes stick through going by the firewall into the engine compartment is probably not going to be re-useable either - I just used a caulk gun and glopped it up from the firewall side. Neatly! None of the steps along the way are all that bad by themselves - but none are real easy either. The "hush" panel or lower dash panel is a pain to get out with the hidden screws up inside - silly design. The screws that hold the two heater housing halves together are located such that they are as hard as possible to remove. Could have been thought about a bit more before it was designed quite that way. I mentioned the retaining clips for the core... I could go on. It was frustration about stuff like this when I was a full time mechanic that made me become an engineer. Of course, I'm not now working anywhere near the auto industry! Have fun - and don't be afraid to ask - I'll help if I can. remer@direcway.com (I won't be around this saturday).
Old Apr 21, 2004 | 07:14 PM
VetteBandit
Default Re: Replacing Heater Core (rons85)
WOW! Thanks for the awsome breakdown and tips!! I dont plan on starting it just yet, but def in the up comming weeks.....any other tips are greatly appreciated! Thanks so far guys! :auto:
Old Apr 21, 2004 | 07:16 PM
HiRiser's Avatar
HiRiser
Did mine last winter. would not do it if it's not leaking :smash:
Old Apr 21, 2004 | 10:20 PM
VetteBandit
Default Re: Replacing Heater Core (HiRiser)
ya i wouldnt but the car is 20 years old and ive heard that replacing it now is better then putting in new carpeting and then having it go......all over the place! Any truth to that???
Old Apr 22, 2004 | 10:53 AM
CFI-EFI's Avatar
CFI-EFI
As you can see it's a horrible job. But as you point out it IS a 20 year old car. It WILL fail. Better to anticipate the problem in warming weather, than get caught needing it and changing it in the cold. If, when, it fails, you will get ample warning by fogging the windshield and the odor, giving you time to "short circuit" the heater hoses before any damage is done, but that won't keep your tootsies warm.
RACE ON!!!
Old Apr 22, 2004 | 11:39 AM
TrueBlue ChevyDude's Avatar
TrueBlue ChevyDude
From: Brandywine, Chester and Ridley Valleys Pennsylvania
Default TBCD Method
Wool sweater, baseball hat, driving gloves.
When the steering wheel gets up close to body temp., take off the gloves. :lol:
Old Apr 22, 2004 | 12:59 PM
VQT88Vette's Avatar
VQT88Vette
Default Re: Replacing Heater Core (90Z51Vette)
Good luck,
Mark
:rofl: me too, and about 40 hours of break time when working on replacing the heater corethose two weekends. Remember to lable ALL the screws to where it should be at. Some screw have different treads than the other.
Old Apr 28, 2004 | 06:32 PM
brob9's Avatar
brob9
7th Gear
Default Re: Replacing Heater Core (VQT88Vette)
I've come up with a leaking core too. I just looked at the instl in my '91 and it looks like it's possible to get to the core from the engine side of the firewall by removing the RH wheel, wheel well inner liner, coolant reservoir, frame-to-latch support brace, blower & motor, and w/s washer reservoir. :lurk: Then, I'm hoping, disassembly of the core housing can begin. I'm also hoping I'll find the heater core in the same housing with the a/c core. If it's under the dash, I'm not even going to go there. :nopity
So . . . whatcha think? :grouphug:
Old Apr 29, 2004 | 01:02 AM
BLIZZ's Avatar
BLIZZ
Default Re: Replacing Heater Core (brob9)
Hey Guys, I just replaced the core in my 95LT1. Purchased a new GM core, before I installed it I had my local radiator shop pressure test it. Guess what?? Leaked all over!!!! Just a word of ADVICE. Good Luck.
Old Apr 29, 2004 | 07:55 AM
brob9's Avatar
brob9
7th Gear
Default Re: Replacing Heater Core (BLIZZ)
Are you kidding me, the NEW core leaked? :eek:
Old Apr 29, 2004 | 08:12 AM
Flame Red's Avatar
Flame Red
:iagree:
If it ain't broke - don't fix it :nono:
This is not a regular maitenance item. Too may posts I have seen where people replace their heater cores and the new one end up leaking shortly thereafter. You will :beatdeadhorse: if this were to happen to you.
Old Apr 29, 2004 | 08:50 AM
TheStef's Avatar
TheStef
Default Re: Replacing Heater Core (Flame Red)
Quick question?
Why do you need to replace to heater core?
Old Apr 29, 2004 | 10:30 AM
brob9's Avatar
brob9
7th Gear
Default Re: Replacing Heater Core (TheStef)
Fumes inside the car can't be eliminated by adding coolant sealer. I'm at the point of bypassing the core just to be able to keep driving it. :banghead:
Old Apr 29, 2004 | 12:06 PM
redvtt's Avatar
redvtt
From: All great change begins at the dinner table Ronald Reagan
I replaced the heater core on my red '85 in a parking lot stall. I pulled the pass seat out, that helped. It does come out from the inside, I didn't need to do much on the outside. The tricky part is r & R the core itself ($70 @ GM). :smash:
Plan a whole day or about $600 + $70 at the dealer. Took me about 11 hours.
redvtt :)
To Replacing Heater Core
Old Apr 29, 2004 | 02:08 PM
brob9's Avatar
brob9
7th Gear
Default Re: Replacing Heater Core (redvtt)
Anything you can elaborate on would be appreciated. :)
Old Apr 29, 2004 | 02:23 PM
91drptop's Avatar
91drptop
Did my 91 vert a few months ago. Went in under the dash per helms instruction. Quick way to check if it will come out through the engine compartment, undo the high surge tank and you can see where the core comes through the firewall. If its a solid piec then probably not, but I can't remember. :confused: :D
Old Apr 30, 2004 | 11:08 AM
brob9's Avatar
brob9
7th Gear
Default Re: Replacing Heater Core (91drptop)
Thanks for all your inputs. Looks like this weekend I'll be taking a hacksaw to the heater hoses, adding plugs & clamps.
Sell it this summer. :party:
