Fuel Filter
Apr 22, 2004 | 09:03 PM
Philly 'Burbs Events Coordinator
Fuel Filter
I'm replacing my fuel filter and the flow arrow points to the back of the car, is that correct :confused:
Apr 22, 2004 | 09:37 PM
Re: Fuel Filter (Rex Ruby)
Nope :nonod:
Apr 22, 2004 | 10:43 PM
I wouldn't guess that was the case? Think about it. :)
Apr 22, 2004 | 10:49 PM
Re: Fuel Filter (froggy47)
Yea I know but the old one was pointing to the back for 40K miles :confused:
Apr 23, 2004 | 05:30 AM
Sounds like it'll work that way, however it may not be catching any crap running the opposite direction.
Check one of your other C4's to see what direction they are pointing towards.
[Modified by chucks88, 5:31 AM 4/23/2004]
Apr 23, 2004 | 07:51 AM
Re: Fuel Filter (chucks88)
Arrow points in the direction of fuel flow.
Apr 23, 2004 | 08:59 AM
ugh. I did this one last weekend... what a PITA it was.
be careful... the return line can set up a syphon that will dump fuel out like crazy...
I ended up with a lovely chemical burn from it... ouch... :cuss
Apr 23, 2004 | 09:22 AM
Re: Fuel Filter (bogus)
Disconnect the line at the tank to prevent the mess.
Apr 23, 2004 | 10:05 AM
CI 2-3-4-5-6-8-9 Veteran
St. Jude Donor '05-'06-'07-'08
Re: Fuel Filter (Steel Blue 91)
Quote:
Nope :nonod:
:iagree:
Apr 23, 2004 | 11:16 AM
Yes. If it's in the return line.
RACE ON!!!
Apr 23, 2004 | 11:24 AM
Is this another ZR1 mystery on your hands??
That said, there is nothing on the c4 that is worse to work on than replacing the stupid fuel filter.. !!!!!
Apr 23, 2004 | 11:40 AM
Re: Fuel Filter (Ruby6spd)
It's the Ruby, doing some PM.
Yea it's a PITA but it isn't that bad :smash:
Apr 23, 2004 | 01:30 PM
Re: Fuel Filter (rodj)
I changed mine while the engine was cold, after sitting overnight.
Surprised-- no gas spray at all, just some dripping.
Apr 23, 2004 | 05:13 PM
I'll bet your car ran like a banchee in reverse! :lolg:
Apr 23, 2004 | 05:31 PM
I guess you've never replaced the heater core
