HELP! Cant get valve cover gaskets on
Old Apr 23, 2004 | 08:20 PM
soundkillr's Avatar
soundkillr
Default HELP! Cant get valve cover gaskets on
I cant get my freaking gaskets on this 87 l98. They are the blue fel pro gaskets, and after I stretch them to fit the valve covers, when I am putting the valve covers on, they keep popping off. Is there no way to put them on, without gluing? I cant even get them to stay in place without holding them. The directions say no glue, or gasket maker? Is there a better brand gasket?
Old Apr 23, 2004 | 08:46 PM
shotchkiss's Avatar
shotchkiss
Default Re: HELP! Cant get valve cover gaskets on (soundkillr)
Are you using the stock valve covers? They fit fine on mine, make sure all the oil is off the covers are the gasket are clean and warm. I had to stretch them to get them on mine, this is hard to explain but I had to make sure they curved up towards the valve cover instead of down towards the motor when they were stretched on, that way they didn't pop off on installation. Don't glue them.
Old Apr 23, 2004 | 09:00 PM
Muffin's Avatar
Muffin
Default Re: HELP! Cant get valve cover gaskets on (shotchkiss)
Throw those worthless pieces of rat poopie in the nearest trash can. Have gone through this with two sets. Glued them in with the best stuff I could buy and they still shrunk to the point that all sealing was lost. Parts store gave me a set of Fel Pro VS 12869 T which look to be a very good product.
Old Apr 23, 2004 | 09:12 PM
chucks88's Avatar
chucks88
Default Re: HELP! Cant get valve cover gaskets on (Muffin)
I use red RTV to keep my gaskets on the covers. I've had the covers on and off many times and have had no leaks.
Old Apr 23, 2004 | 09:27 PM
*89x2*'s Avatar
*89x2*
From: ...tearing up the highways, one state at a time™®©
I have used gasket adhesive w/ no ill results :cheers:
Old Apr 23, 2004 | 09:44 PM
soundkillr's Avatar
soundkillr
Default Re: HELP! Cant get valve cover gaskets on (*89x2*)
Ill try some house hold cement or something on the corners. This is driving me crazy. Thanks so much for all the replies... :cheers:
Old Apr 23, 2004 | 11:12 PM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
Glue them to the VCs with weatherstrip adhesive... the yellow stuff..
Wait until the glue sets up then install them.
Sometimes I will set the valve cover upside down and set a book or two on the gaskets to hold them while the adhesive dries.
Edit: I see you have an 87... put on the gorilla snot weatherstrip adhesive,
set the covers upside down and put your bolts through the holes to hold them alighned while the glue sets up.
[Modified by VetNutJim, 10:13 PM 4/23/2004]
Old Apr 26, 2004 | 08:32 AM
Swirk's Avatar
Swirk
Default Re: HELP! Cant get valve cover gaskets on (VetNutJim)
I tried two sets of the Felpro gaskets, both were too short. Bought a set from the dealer. They were better, but still a touch short. I started my little propane heater and set them about 3 feet away from the end. Let them heat up, slowly. Then stretched them enough to put on the valve covers, drop the valve covers on the heads and that was it.
Old Apr 26, 2004 | 08:57 AM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
An old hotrodder tip is to tape them on with the vinyl electrical tape. Leave a folded over tail on the tape. After you set the valve cover on the head you can lift it up a bit and pull the tape off. It is not real easy and there is some cussing involved but with patience it will work! :smash:
Old Apr 26, 2004 | 09:49 AM
jerkyboy's Avatar
jerkyboy
Default Re: HELP! Cant get valve cover gaskets on (corvetteronw)
:iagree: I have been using the 'ol tape method with those same Blue Felpros. I am going to have to glue them down though. Slippery suckers when you get oil on them!
To HELP! Cant get valve cover gaskets on
