Headers and Starter Problem.... Need A Mini Starter
Old Apr 24, 2004 | 01:14 PM
stock86vette's Avatar
stock86vette
Default Headers and Starter Problem.... Need A Mini Starter
Well the SLP long tubes look and sound great! But they dident get along well with my starter.... Heat Soak! So I'm looking for a MINI Starter, any advise on the best one, where to get it and who has the best deals? :confused:
Old Apr 24, 2004 | 02:35 PM
JAKE's Avatar
JAKE
Default Re: Headers and Starter Problem.... Need A Mini Starter (stock86vette)
Most times it's the solenoid that is getting the heat soak and causing the problem; happened to me after installing TPIS long tubes.
I bought a solenoid heat shield from AutoZone for less than $10 - and, of course a new solenoid, - and everything has been working fine for some years now. Still using the same old starter.
Jake
Old Apr 24, 2004 | 02:37 PM
Nathan Plemons's Avatar
Nathan Plemons
Huh, mine's just fine. The LT1 uses a fairly small gear reduction starter from the factory, maybe that's the difference. If the starter from an LT1 will bolt up you might try that, assuming they are in fact different.
Old Apr 25, 2004 | 02:08 AM
olman's Avatar
olman
Default Re: Headers and Starter Problem.... Need A Mini Starter (Nathan Plemons)
Summit has mini starters around 150.
To Headers and Starter Problem.... Need A Mini Starter
