The Best Spark Plugs?
Chevy engines like Chevy plugs. I have used other brands in carbed Chevy's, and always had problems. Never tried with this EFI motor, however, maybe EFI is more forgiving.
Stay away from the high priced gimmick plugs. Bosch + 4's, Splitfires, NGK Iridiums, etc.
Some will disagree here, but NGK Iridiums, while working great on a perfectly running car, tend to foul quickly if something like an O2 sensor goes out - leaving you with a no-start conditions. I replaced the plugs....with expensive NGK TR55 IX (Iridium plugs) and had the same thing happen, before I realized I had a faulty O2 sensor. So now I am down over $100 in SPARK PLUGS.
IMHO, Id rather have the piece-of-mind knowing if I was out somewhere away and an O2 sensor failed, Id be able to limp home instead of being left with a no-start condition.
Just my $.02
Just my $.02
I have been running the NGK's since they came out - about 2 years? Well over 35k miles, and they are fine.
Then again, I did just replace the O2s... :D
Which reminds me, they are due again!
Just my $.02
that is odd... I have always been under the influence that a super fine electrode would have been less prone to fowling...
I've heard that before about platinum plugs, on a perfectly running stock engine, go for it, but on an engine that might not have the 100% perfect A/F ratio all the time you're better off with normal plugs. It was due to the size of the firing tip. I can only assume that the problem would be amplified by the smaller tip of the Iridium plugs.
I don't have any personal experience witht he matter but I have heard it before. Personally I can't justify $100 for a set of spark plugs. If you figure a normal set of plugs will last 30,000 miles and I can get them for $11. That's 300k miles worth of spark plugs before I equal the cost of the high dollar plugs.
