Engine Harness 92 LT1
Old Apr 29, 2004 | 11:00 PM
CorvetteZ51Racer's Avatar
CorvetteZ51Racer
Default Re: Engine Harness 92 LT1 (luvmy92)
MadMikee
You shouldn't have a problem if you use a GM-based program where you can disable the VATS system. I must admit I'm unsure about the Accel computer and how it works, but you will want to play with it enough to find out about the VATS function. If it's there and you can turn it off, the wiring harness that LuvMy92 has will be perfect for your application. It's brand new right now, and we're only going to be using it to hook up the fuel injection on his new 383 when we tune it on the waterbrake dyno here at the shop. I'm doing the full setup and teardown, and can assure you it will be as-new when it comes off the dyno.
