What is the stock oil pressure on an L-98 warmed up at an idle. I know if its in the teens its not good, but mine was around thirty pounds today. I thought it used to be more but im just wonderin :crazy: Just rebuilt the engine this winter.
I know there's variation on this as the helms manual says 50-70 cold
and obviously lower when hot (cant remember). My 85 is in the low
50's when cold and at warm idle (500-550 rpm's) 12-15 ...
So I would say if you're at 30 psi warm idle, you're good.
Rule of thumb 10 psi for every one thousand rpm's..
