84 fuel pressure question
Old Apr 27, 2004 | 01:48 PM
da747's Avatar
da747
Default 84 fuel pressure question
im looking to get some stainless braided hose to mount a pressure gauge between my throttle bodies on my 84.... anyone know what the thread sizes are on the TB's so i get the right hose? thanks
Old Apr 27, 2004 | 03:50 PM
ben73's Avatar
ben73
Default Re: 84 fuel pressure question (da747)
There is a recent post on the crossfire forum about this. It has all the info you need. I think 'elkabong' is the member you will want to search on.
Ben.
Old Apr 27, 2004 | 08:37 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: 84 fuel pressure question (ben73)
One of the forum members posted a picture a month or so ago. It very well may have been elkabong. It looks like it ought to do a good job, but it was quite a "rats nest" of stainless hose and red and blue fittings. He probably has as much money wrapped up in that set up as I have in all my mods, altogether. I simply sectioned an inch or so out of the line that runs between the TBs and installed a tee fitting. I have a Shrader valve screwed into the tee. Now I can check fuel pressure at any time, just the the bigger TPI boys. That includes while making a run throught the 1/4 mile.
RACE ON!!!
Old Apr 27, 2004 | 11:14 PM
da747's Avatar
da747
Default Re: 84 fuel pressure question (CFI-EFI)
didnt think of that. how did u seal the tube ends into the T? thanks
Old Apr 28, 2004 | 09:07 AM
silver84's Avatar
silver84
I don't know why you want to do that, but
be sure to upgrade to an 85 fuel pump
before trying to solve low-fuel-pressure-issues.
:auto:
Old Apr 28, 2004 | 11:24 AM
da747's Avatar
da747
Default Re: 84 fuel pressure question (silver84)
if the fuel pressure is ok i dont have to change the pump. also i could find problems with the rest of the fuel system.
Old Apr 28, 2004 | 11:31 AM
CFI-EFI's Avatar
CFI-EFI
The tee I bought was for a 45* inverted flare fitting at two positions. Besides the tee, I had to buy two 45* inverted flare fitting nuts. That is the same connection at the TBs. I double flared the tubing ends where I cut it, and screwed both ends in to the tee. Install the nuts on to the tubing before you flare it. The tee I selected had a 1/8th inch pipe thread for the third hole. I screwed in a $5.00 tire pressure valve to complete the set up. I'm sure I don't have $15.00, total invested.
RACE ON!!!
[Modified by CFI-EFI, 9:45 AM 4/28/2004]
Old Apr 28, 2004 | 11:34 AM
scorp508's Avatar
scorp508
Its your car, but permanently mounted mechanical fuel pressure gauges in the engine bay scare the hell out of me. If it ever fails from the constant jarring of the suspension you'll have a firey mess and won't know it has failed until its too late.
Old Apr 28, 2004 | 05:09 PM
elkabong's Avatar
elkabong
Here is my high priced rats nest.
Old Apr 28, 2004 | 07:31 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: 84 fuel pressure question (elkabong)
My appologies for the 'name calling", but that is the photo, I was refering to. Thanks for the pic and being a good sport.
RACE ON!!!
Old Apr 28, 2004 | 08:04 PM
elkabong's Avatar
elkabong
No problem... my feelings are not hurt. You are right however..... I did spend too much money on the red and blue stuff. :yesnod:
Old Apr 28, 2004 | 11:04 PM
da747's Avatar
da747
looks cool though! too bad you cant see it all the time.
Old Apr 29, 2004 | 03:04 AM
JoBy's Avatar
JoBy
I used EARLS parts.
#991945 12mmx1.25 to AN6 ( Carburetor Adapter Solex, Dellorto, Mikuni )
#300106 AN6 Straight Auto-Fit Hose End
#304606 AN6 45deg Bent Tube Auto-Fit Hose End.
Old Apr 29, 2004 | 04:10 PM
da747's Avatar
da747
Default Re: 84 fuel pressure question (JoBy)
thank you for the info. i might just get the hose ends and a T, and make a simple hose just to use when the air cleaner is off. i couldnt test the pressure under full load, but i wouldnt need all those angles.
To 84 fuel pressure question
