Question on SLP runners
Old Apr 27, 2004 | 06:27 PM
gene284's Avatar
gene284
Default Question on SLP runners
Do you have to raise the fuel rail to install the runners?
If so, did you replace all the injector o-rings?
Old Apr 27, 2004 | 06:31 PM
Pete K's Avatar
Pete K
Default Re: Question on SLP runners (gene284)
1) yes a little 2) no, but not a bad idea if it hasn't been done in a while
Old Apr 27, 2004 | 07:09 PM
FlyboyZR1's Avatar
FlyboyZR1
You shouldn't have to touch the fuel rail when installing new runners.
You will have to remove the cold-start injector though, or at least bend it out of the way to manipulate the runner out.
Old Apr 27, 2004 | 08:05 PM
gene284's Avatar
gene284
Default Re: Question on SLP runners (Pete K)
Pete:
Had to raise it a little bit just like you said. The runners were obstructed between the manifold bolts and the fuel rail.
Curious if you have SLP runners. If so, the runner closest to the driver, does it have a light belt sanded flat at the top? Or was this done by the previous owner? Wondering if it was to prevent abrasion to the throttle cable near the firewall.
Old Apr 27, 2004 | 08:16 PM
Pete K's Avatar
Pete K
I used the slp runners from 1993-1998. I ran out to garage cabinet to look. I bought mine new and they do have that same spot ground a bit. I assume for the reason you mentioned.
Old Apr 27, 2004 | 08:30 PM
gene284's Avatar
gene284
Thanks for checking Pete.
I just sandblasted and painted these a Chevy truck charcoal metallic color, they look like magnesium now. Didn't want to spend the rest of my life polishing these castings to make them look good.:crazy:
After painting I noticed the belt sending on the one runner. Thanks for verifying it was a factory deal.
By the way, my second choice was Chevy orange, but didn't want to look too "in your face". The magnesium look is more subtle, think it will grow on me.
Thanks for running out in the garage to look.
To Question on SLP runners
