4+3 clutch/slave?
Old Apr 28, 2004 | 06:31 PM
redfast's Avatar
redfast
Default 4+3 clutch/slave?
When im moving slightly and push the clutch down the gears in the trany sound like there grinding. I think its the slave cylinder but not too shure because I don't know much about these trany's. Thanks :thumbs:
Old Apr 29, 2004 | 07:02 AM
byte_me's Avatar
byte_me
Default Re: 4+3 clutch/slave? (redfast)
Well looking at the fluid would be a good start- is it black? Back when I had my 4+3 (now converted to a ZF6)I had strange problems that came from bad thick fluid and a bad slave cylinder...the slave didn't push the yoke far enough to engage or disengage all the time...as soon as I swaped it- it worked like it should- I also had issues with the Overdrive unit carrier bearing keeping the 4 speed locked in gear with the clutch dis-engaged! Thus I moved to a more stable platform with the ZF...again, a sure sign that the system is struggling is black nasty clutch fluid...mayb a simple drain\clean and bleed will do the trrick!
Good luck...
