I'm having a major issue with my 84, my average mpg has dropped from 24 miles to the gallon to 13-15 miles to the gallon. There is no apparent leaks in the throttle body gasket or the intake manifold gasket. I have replaced the distributor cap, Rotor, and installed split fire plugs. Re-timed it to +6 degrees. I have also replace the ECM unit with no success. For some reason I continue to get the check engine light (Same code 44) but the mileage jumps back to 24 after the light comes on. It will remain at the better gas mileage until I shut her down. I have to have a bad sensor some where anyone got any ideas????
[Modified by JDKUG, 1:56 AM 4/29/2004]
:steering: Thanks everyone for your responses, The winner was Pete K. I replaced O2 Sensor and I'm back at 24mpg Thanks for the Support.... :party:
A code 44 relates to a lean condition. I have seen a bad o2 sensor cause this but there are other causes possible. I would change sensor if it is older than 5 years and 50k. Otherwise a scanner will show o2 millavolts and tell you if it is bad. Hope this helps.
Could be as simple as a broken vacuum line. I replaced all vacuum lines on my 84 a while back, as they were all rotten as hell.
How many pounds of vacuum do you have at idle and is the needle steady?
Also, does it idle high? Any chance there is an IAC stuck open? A broken vacuum motor in the thermac? Somehow the engine is ingesting more air than the ECM thinks it should, and it could be richening the mixture to compensate, thus killing your mileage.
When it sets the light it may be going back into open loop (limp home) mode, which is causing the funny readings on the MPG display.
The 85 is a TPI with the pressure regulator on the return line. On the 84, the fuel pressure regulator is integral on the rear throttle body.
Physically, the regulators are in different locations. The TPI regulator is a stand alone unit. As stated, the Crossfire regulator is built into the rear TB, but it regulates the pressure at the return line. Functionally, they are the same.
Another cause of a code 44, could be a fresh air leak into the exhaust system. Additional unburned air will cause a lean reading from the O2, and the ECM will try to richen it, killing your gas mileage. Good luck, and...
