Fuel Pressure Question...
Old Apr 29, 2004 | 06:15 PM
darkman5001's Avatar
darkman5001
Default Fuel Pressure Question...
I need to set my fuel pressure on my 86 now that I have a Holley AFPR and abrand new set ofFord MotorSport 24# injectors. What should I set the pressure at so my engine does not run too rich? I have a custom chip done by Ski_dwn_it also, along with a magnaflow catback, random tech cat, and hooker 2149 headers and a hooker y pipe. Not sure if any of these mods make much difference but I thought I would list them anyways. I also have a smog pump system bypassed. Thanks!
Old Apr 29, 2004 | 07:11 PM
geezel's Avatar
geezel
Default Re: Fuel Pressure Question... (darkman5001)
I've got an 86 with about the same mods plus a cam. I know you can go a lot higher, but mine seems to run best set at 40 PSI (at idle with vacuum disconnected).
Old Apr 29, 2004 | 08:33 PM
JAKE's Avatar
JAKE
Default Re: Fuel Pressure Question... (geezel)
WOW!
That's not much at all. With the vacuum line connected it would be in the very low 30's.
Jake
To Fuel Pressure Question...
