Digital cluster connector Diagram
Old Apr 30, 2004 | 02:47 PM
eric_daniel's Avatar
eric_daniel
Default Digital cluster connector Diagram
The following diagrams are from a 1986. Does anyone know if the 1985's connector is the same or different?
http://batee.com/corvette/dcrg/wirin...tor_pinout.htm
Thanks guys
Old Apr 30, 2004 | 02:49 PM
bogus's Avatar
bogus
Default Re: Digital cluster connector Diagram (eric_daniel)
I think all 5 model years share the same harness.
Namely, because you can install the cluster from an 89 into an 84...
Old Apr 30, 2004 | 04:09 PM
JAKE's Avatar
JAKE
Default Re: Digital cluster connector Diagram (bogus)
I remember a couple of years ago I tried helping a buddy with his digital dash problem on his 1985 Vette.
I plugged his dash into my 1986 and everthing worked as usual EXCEPT it showed two digit RPM numbers at idle speeds below 1000 RPM.
Instead of reading 9, for 900, it read 90; instead of 8 for 800 it read 80. Other than that, all other functions worked normally.
Jake
To Digital cluster connector Diagram
