93LT1 electrical question
Old May 1, 2004 | 04:39 PM
vetteman9368's Avatar
vetteman9368
From: I have no tolerence for liberals and fools, but sometimes i repeat myself
CI 3-5-7-8-9 Veteran
St. Jude Donor '08
Default 93LT1 electrical question
whats the best underhood source for an ignition hot Lead?
Old May 1, 2004 | 11:41 PM
93Quasar's Avatar
93Quasar
Default Re: 93LT1 electrical question (vetteman9368)
Is this for heated O2's? I may be soon doing the same thing.
Old May 2, 2004 | 10:24 AM
Nathan Plemons's Avatar
Nathan Plemons
What's it for? If you want it on with the ignition an excellent source is one of the fan relays on the driver's side radiator shroud. If you're going for heated O2 sensors you don't really want it on whenever the key is, rather you just want it on when the engine is running. The fuel pump relay is a good place to pick that up from.
I know because I've done both :)
Let us know what you need it for exactly and I'm sure we can find you a prime spot. :cheers:
Old May 2, 2004 | 11:01 AM
vetteman9368
St. Jude Donor '08
Default Re: 93LT1 electrical question (Nathan Plemons)
i need one for the heated O2's and one to trigger the relay for the water pump. I figure one of the fan relays will work for the pump, but what color is the right wire? And where is the fule pump relay and what color wire?
Old May 2, 2004 | 09:02 PM
93 ragtop's Avatar
93 ragtop
The fan relay to TRIGGER the water pump relay is pink with a black stripe. I emphisize trigger because you do need a seperate relay for power. And by the way, there is a lug above the battery to pick up power for the pump.
Old May 2, 2004 | 11:48 PM
vetteman9368
St. Jude Donor '08
Default Re: 93LT1 electrical question (93 ragtop)
i already have the relay wired, just need an ignition hot (and with all the electrical not done yet don't ant to actually turn it on, lol). Battery has been relocated to the rear and i have a juncton block up front now. Now for where to tie in for the heated O2's :confused:
To 93LT1 electrical question
