For the record this is wrong!
Old May 1, 2004 | 11:05 PM
crheinish's Avatar
crheinish
Default For the record this is wrong!
http://www.theherd.com/articles/lt4_temp.html
The information in the above article was posted on this forum recently. I did this modification on my Corvette and used Delco parts. The coolant temperature sensor recommended in the article reads 15 degrees higher in temperature than the OE. I then put my vehicle back the way it was. Just wanted to pass that information along. :cheers:
Old May 2, 2004 | 03:27 AM
FD2BLK's Avatar
FD2BLK
Default Re: For the record this is wrong! (crheinish)
The sending unit in the article is the same one the ZR1 uses. I used this set up on my 84 when I installed the LT1 with no problems. I wounder if you got a bad sending unit? FWIW I would recomend staying with the stock set up the only reason I went with that set up on my 84 was because it was just a simpler way for that aplication. Good info though.
Old May 2, 2004 | 09:01 AM
Lionsden's Avatar
Lionsden
How did you verify that 15 degree error was in the conversion and not in your oem system? If the oem was working correctly why would you want to do the conversion? :confused:
Old May 2, 2004 | 02:12 PM
crheinish's Avatar
crheinish
Default Re: For the record this is wrong! (Lionsden)
Error was verified by my digital temp readout and a thermometer. Re-read the article and you will answer your second question. :cheers:
Old May 2, 2004 | 02:37 PM
Lionsden's Avatar
Lionsden
Well, Duh! If I had read to complete article I would have know why. :bb It does make one wonder why yours wasn't accurate and others seem to not have a problem.
Old May 2, 2004 | 02:59 PM
JasonL's Avatar
JasonL
Interesting info. Well I guess I have 3 comments/questions/whatevers :D
1. Where did you place the thermometer? If there is a discrepancy between the thermometer and digital dash reading, that's a problem. If there is a discrepancy between the digital and analog guages (after the mod) then I would somewhat expect that since the analog guage probably isn't calibrated perfectly anyways (e.g. rounded to the nearest five, made to look pretty, etc)
2. This mod probably isn't necessary on the C4 since we have a digital guage which reads off the PCM sending unit.
3. Few years ago a member reported overheating his LT1. He said the guage sending unit showed the temp increase much earlier than the PCM unit. So I'd be inclined to keep the cylinder head sensor as an earlier signal of impending doom. :)
Old May 2, 2004 | 03:08 PM
crheinish's Avatar
crheinish
I think because 92 up Corvette has a digital temp. gauge from the factory. The other LT1 equiped vehicle only have an analog. :cheers:
Old May 2, 2004 | 03:13 PM
crheinish's Avatar
crheinish
Default Re: For the record this is wrong! (84LT1)
Not from my research. The ZR1 did not use the sensor in the article.
Old May 2, 2004 | 10:03 PM
FD2BLK's Avatar
FD2BLK
I stand corrected :bb I thought the article used the same sensor I did but the P/N I used was 10096181 (Sensor) 02748 (Three wire pig tail) and they where used on the 94-95 ZR1 mabey thats why I had no problems?
Old May 3, 2004 | 01:16 PM
crheinish's Avatar
crheinish
90-95 ZR1 never used a 3 wire CTS. The correct CTS part # for 94-95 ZR1 is 15326386 and it is a 2 wire sensor. :cheers:
[Modified by crheinish, 10:18 AM 5/3/2004]
To For the record this is wrong!
