SuperRam TV cable related questions
Old May 2, 2004 | 07:58 PM
flyersfan1088's Avatar
flyersfan1088
From: What did the 5 fingers say to the face? SLAP!!
Default SuperRam TV cable related questions
How in the world are you supposed to hook up the TV cable?! In the archives, I saw someone mention something about a different bracket. Where do I get one and how much? Also, can the cable be routed with the cruise and accelerator cable, or does it have to be routed on the inside of the runner? Thanks
Old May 2, 2004 | 08:22 PM
ralph's Avatar
ralph
Default Re: SuperRam TV cable related questions (flyersfan1088)
The bracket came with my SR. LPE should have them and i can't imagine they're too much $. It angles the throttle and cruise cables up and the TV cable down......And yes everything fits.
PS...put the TV cable under the plenum
[Modified by ralph, 8:22 PM 5/2/2004]
Old May 2, 2004 | 08:26 PM
flyersfan1088
Default Re: SuperRam TV cable related questions (ralph)
I really don't relish the thought of pulling the plenum again. Will it not work if I run it on the outside of the runners?
Old May 2, 2004 | 09:32 PM
ralph's Avatar
ralph
I've did the same thing the first time i installed mine. It works but it puts a sharpe bend in the cable a bit right behind the bracket. You can always straighten it out next time to have to remove it. Good luck
Old May 2, 2004 | 10:23 PM
Vic'89's Avatar
Vic'89
The TV cable goes under the plenum. That is the correct method.
Vic
Old May 2, 2004 | 10:39 PM
DBLAZER4's Avatar
DBLAZER4
Default Re: SuperRam TV cable related questions (Vic'89)
i installed mine over the plenum and it works fine. it puts about the same bend in the cable as going under the plenum.
Old May 2, 2004 | 11:38 PM
Ramanstud's Avatar
Ramanstud
Default Re: SuperRam TV cable related questions (DBLAZER4)
check ebay for the bracket- every once in a while one crops up for $10 or so. Also do a search for TPI parts, a lot of the Aftermarket TPI (stand alone or retrofit) companies will carry them as well.
:cheers:
PS Pull the plenum off and do it right- the last thing you want to do is FUBAR that cable and then have to replace it (getting to the tranny linkage is a b*tch). And you can rest peacefully knowing that all is right with the world. :D
To SuperRam TV cable related questions
