I need some advice on a connection to the throttle body butterfly arm on my 87. I need some info on how to get the plastic connector off the upper part of the throttle shaft arm. The 2 lower ones are easy but the plastic one on top is a mystery. It is a 17 year old plastic part that is probably brittle and will break easily. Is it a push fit ? Pry off with a screwdriver ? Slide it one way or the other ? HELP !!
