Where to get caps for Hooker 2149s????
Old May 2, 2004 | 10:51 PM
darkman5001's Avatar
darkman5001
Default Where to get caps for Hooker 2149s????
I am going to be plugging the AIR tubes on my new Hooker Headers (2149s.) Where can I get these caps?? They come in from Jet Hot any day, and they are going on Saturday. I have an 86. Thanks!
Old May 2, 2004 | 10:58 PM
DBLAZER4's Avatar
DBLAZER4
Default Re: Where to get caps for Hooker 2149s???? (darkman5001)
take your stock header with you to home depot and find a brass fitting that will fit. that is what i did. it will be less than 5 dollars for both fittings.
Old May 3, 2004 | 07:36 PM
darkman5001
Default Re: Where to get caps for Hooker 2149s???? (DBLAZER4)
Well due. I'll give that a try.
[Modified by darkman5001, 12:44 AM 5/4/2004]
Old May 3, 2004 | 07:38 PM
scorp508's Avatar
scorp508
Home depot 1/2" pipe caps for $0.39.
Old May 3, 2004 | 07:47 PM
darkman5001
Default Re: Where to get caps for Hooker 2149s???? (scorp508)
Half inch. Sounds better than carrying the header or old manfold in. What kinds of metal should they be made of? Do they make stainless steel or aluminum?? :cheers:
Old May 4, 2004 | 03:55 PM
NavyVet's Avatar
NavyVet
Scorp's right - I used brass. One easier solution would have been to take the valve that screws on the fitting (without the hose) with you to Home Depot, insert a male pipe into it for sizing, and then buy the female cap that fit. A lot easier than carrying the whole header. Paul
Old May 4, 2004 | 04:47 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
1/2 inch.. :yesnod: One of your local industrial supply shops might carry SS.
Old May 5, 2004 | 08:29 AM
dave_85's Avatar
dave_85
Default Re: Where to get caps for Hooker 2149s???? (CentralCoaster)
Paint the caps black. Then it won't look like your car was put together with parts from Home Depot. ;)
To Where to get caps for Hooker 2149s????
