Tires
Old May 3, 2004 | 03:48 PM
Stingray1970's Avatar
Stingray1970
Default Tires
have C5 wheels for my 91, undiecided as to the size for the front. undecided as to 255/40 or 45 /17'S. Any feed back is appreciated.
Thanks in advance
Old May 3, 2004 | 04:33 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Tires (Stingray1970)
Well stock was 245/45 so if you are going wider you could go a little lower in sidewall.
If you like handling and/or looks I would go with the widest tread; if drag racing is your preference go with the narrower tread (taller).
Old May 3, 2004 | 04:52 PM
Cherry6speed's Avatar
Cherry6speed
Check out Hawaiian Punch's Thread in the c-4 General discussion section. He has C-5 rims on his and they look Totally awesome. :seeya http://forums.corvetteforum.com/zerothread?id=810868
Oops Z-06....well
[Modified by RUBYREDVETTECARD, 9:54 PM 5/3/2004]
[Modified by RUBYREDVETTECARD, 9:55 PM 5/3/2004]
To Tires
