Pulled ECM Fuse, code not gone but...
Old May 3, 2004 | 10:22 PM
V's Vette's Avatar
V's Vette
Default Pulled ECM Fuse, code not gone but...
I really didn't want to lose all of my radio settings so I pulled the ECM fuse. The trouble code did not disappear, so I just decided to leave it since things are fine (it was a code 36 and I replaced the MAF relays).
Then, several days later I used the old paper clip and...the code 36 was gone. Why would that happen when I had not done anything after the fuse pull to cause it to disappear?
Old May 3, 2004 | 10:33 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Pulled ECM Fuse, code not gone but... (V's Vette)
That may be forever a mystery.
You can reset only the ECM by opening the connector in the Orn wire near the battery for a minute or so; this may be easier than gaining access to the fuse holder.
Old May 4, 2004 | 10:29 AM
c4cruiser's Avatar
c4cruiser
Some codes are set in history and will not disappear simply by removing power to the ECM. Using a paper clip to clear codes is what has to be done to clear any history codes.
Old May 4, 2004 | 02:45 PM
Bluevette85's Avatar
Bluevette85
Your code disappeared because you ran the car thru enough start and stop cycles without a code present.
To Pulled ECM Fuse, code not gone but...
